20 Most Recent Archos AV700 Digital Media Player Questions & Answers
Turn on the Archos AV700.Locate the "Stop/ESC" button on the right side of the AV700 Press down the "Stop/ESC" button for 15 seconds. The Archos AV700 will reset OR Update your Archos device ..follow this link->archos.com/support Download firmware->start download
Archos AV700... | Answered on Jun 02, 2011
I can not charge av700 ,then I buy new battery from ebay USA after I get it I change new battery and plug in it working very good then I left it plug in 6 hours ,after I put off plug and try to turn on av700 but cannot turn on then I plug in again now cannot charge happen nothing,So what can I do now.([email protected])
Archos AV700... | Answered on Mar 14, 2011
Hi.
Flip out the batteries for one minute, then put them back in place.
Try replacing the batteries. If you use rechargeable batteries, this may be defective.
Try connecting the Archos to a computer, and see if it start connected to a computer. If it starts go to the screen Settings > System and press and hold the DOWN action button for three seconds. A button "Format HD" will appear. Use this button to format the AV 700's hard drive. Doing this will erase all the data on the AV 700's hard drive.
If the unit starts up, try also updating the firmware. Here the page.
Here how to install.
Try entering in recovery mode.:
To enter into the Recovery screen
- Turn off the device and wait 10 seconds.
- Press and hold the volume + button while powering on the device.
- Keep the volume + pressed until the Recovery mode starts (white screen).
- To move from one option to another, use the volume buttons. To select an option, press the ON/OFF button.
Recovery mode options
No: Cancels the system recovery.
Update firmware: Allows you to connect your device to a computer in order to copy the latest .AOS file (operating system) to your device and then install it.
Repair System
: Attempts to repair the file structure on the internal memory. This does not erase any data.
No: Return to main recovery screen.
Force Touchscreen Calibration:
Select this and then select no to leave the recovery screen. Upon restarting, the ARCHOS will immediately start the touch-screen calibration utility.
Check Disk: Check and repair the system partition if damaged.
Start USB MSC: Allows you to connect your device to a PC to access the internal memory.
Format System: Formats the internal memory. All data (music, photos, videos, etc.), applications and settings are erased. "
If all that does not work, contact Archos and book a repair.
Here a manual.
Archos AV700... | Answered on Mar 12, 2011
I found a driver for you to download for free from this website: http://drivers.softpedia.com/get/FIRMWARE/Archos/Archos-AV-700-TV-Firmware-1609.shtml
Hope this helps.
Archos AV700... | Answered on Dec 23, 2010
Managed to resolve my dark screen issue. It is a little weird and not sure which combination actually got it going but it works. I firstly connected the TV POD unit to the AV700 and used the remote and no joy. With the TV POD unit still connected, I fiddled with the battery latch switch a few times and VOILA! - the screen came back to life and all is now good.
I hope it is as easy as that for all of you....
Archos AV700... | Answered on Sep 23, 2010
what was the very last software / file/ cd/ dvd or game downloaded on to pc
put your recovery disk in
Archos AV700... | Answered on May 21, 2010
If your player hard drive can be seen, try deleting and recreating its partition (using Windows Aministrative Tools->Computer Management-> Disk Management) before trying to FULL FORMAT it again.
Archos AV700... | Answered on Dec 26, 2009
connect it to computer and try to recover it using this software: http://www.recuva.com/
remember selecting right device..
it may take hours to search the drive for deleted files..
if this does not work mail me on [email protected] and i start talking about some more advanced recovering softwares and such ..
Archos AV700... | Answered on May 25, 2009
is your usb lead broke, or maybe your computer is not picking it up, try opening my computer and see if you can find the hard drive, then just open it up and you will find the folders, let me know if this is any help
Archos AV700... | Answered on Mar 22, 2009
have you tried resseting the unit?
Mike
Archos AV700... | Answered on Jan 13, 2009
take the battery off and there is a reset button on the back this should solve the problem.
Archos AV700... | Answered on Dec 30, 2008
Archos AV700 Digital Media Player Logo
53 questions posted
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Archos Audio Players & Recorders
Most Popular Question
40gb archos
  • Audio Players & Recorders
