20 Most Recent Amana SCRATCH&DENT 25 Cu. Ft. French Doors Refrigerator (BLACK COLOR) AFD2535DEB Questions & Answers
If the compressor didn't come on the freezer wouldn't work at all. The problem is in the inside fan on the fridge side.
Amana... | Answered on Nov 09, 2017
you only want 1/8 th inch all the way around the door make sure to level hinged sides and shim them in make sure to constantley look by opening and closeing door that you have 1/8th all the way around
Amana... | Answered on Sep 30, 2014
yes if you have an hinge which looks like small flag there are 3 ajustment places on these you need the one pointing towards glass on tip of flag normally small white cap on front take off and use allen key and it wind back towards wall taking off the drop to it if not flag hinge you will have to call engineer ok hope this helps bub
Amana... | Answered on Jan 09, 2010
Sounds as if you have a bad timer or a cold control They can be replaced. Most likely it is the cold control
Amana... | Answered on Jul 15, 2009
  • Hi: You did your homework and checked everything. You said you checked the water flow to the refrigerator, and it was fine. Although what you described sounds like no or low water flow to the solenoid. I'm referring to the valve the water line is connected to. When they "rattle" it means there is not enough or no water pressure keep them open. These valves usually have a gravel filter. As you say it's a scratch and dent. The filter may clogged with gravel, or mildew (as it sat unused as a scratch and dent for who knows how long.) You sound handy. Before I replace that valve I would remove it and look where the inlet water is attached. Usually there is a screen behind a cap you will have to unscrew the size of an garden hose cap. See if there is a screen that can be cleaned. I'll lind the Sears parts direct page to you with the part no. #10 on the diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=AFD2535DEB&productCategoryId=0161000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00012&componentDescription=CABINET BACK&documentId=M0705005&backToLink=Return to Sub Components list The clogged screen would make the valve vibrate like you described. I hope this helps, Jeff
Amana... | Answered on Jun 26, 2009
raise the front legs/rollers so unit is tipped back slightly.its ok if it opens as long as it closes.
Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section ( mostly on SxS refrigerators )
Also please read through the suggestion in the webiste provided bellow:
http://www.applianceaid.com/frig_notcold.html
Thank You
Amana... | Answered on Jun 02, 2009
you may some save $ by changing just the stainless skin outside the door. GE did on mine.
good luck
Amana... | Answered on Feb 09, 2009
pencj,
My honest answer is that I have seen this before and in most cases the board works properly after the reboot.
Although you may not have lost power, you may have gotten a voltage spike. I would cancel the service man coming out, (I am a working service man myself) he probably will give you two options. #1 Wait to see if this happens again and if it does happen again soon, the board should be replaced. #2 replace the board now.
My suggestion is to soon go purchase a surge suppressor to plug into. This does not need to be a power strip style. A good quality suppressor that only has one or 2 plug in's or plugs directly into the wall receptacle should do fine. Your refrigerators maximum amp draw is listed on the model # sticker inside the refrigerator compartment.
I hope this helps, supertechks
Amana... | Answered on Dec 10, 2008
Vacuum cleaner, plus there are long brushes available
https://www.homedepot.ca/product/everbilt-universal-appliance-brush-set-2-pack-/1001420993
Amana... | Answered on Sep 06, 2020
Request from Amana or an appliance dealer.
Amana... | Answered on Jul 22, 2020
usually in back on top of or near compressor or in the front of fridge u have to remove the panel to see it
Amana... | Answered on Mar 12, 2020
pan is usually located on back or front bottom you may have to remove back or front pANEL TO ACCESS
Hello Dennis;
My name is Peter. I am a retired field service technician.
You did not provide a model number. So, I am going to speak in general. It sounds like you have a bad or stuck contact switch. Or, you ice dispenser handle is broken and activating the dispenser.
You contact switch will look like the following:
There are two slots on the bottom of the dispenser frame for a flat head screw driver. Pop the bottom out. The rest of the frame is held by plastic tabs. Push in the sides to remove the frame.
Ground yourself by touching something that is steal. Static electricity will knock out a board. Remove the board. You will see the contact switch.
Send me the model number and I can be more specific.
Go into the following web site and put in your model number for diagrams and the part number.
Water Filters Lawn Garden Appliance Parts
Amana... | Answered on Jan 08, 2020
Amana SCRATCH&DENT 25 Cu. Ft. French Doors Refrigerator (BLACK COLOR) AFD2535DEB Logo
Popular Tags
18 questions posted
Top Amana Refrigerators Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
just bought amana bottom freezer
  • Refrigerators
