20 Most Recent Haier HLH326BB 32 in. LCD HDTV Questions & Answers
Haier Model HLH326BB LCD TV. When I turn it on, the screen comes on for a split second and then goes black, but the audio is fine??
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board. http://electro-medical.blogspot.com/
12/1/2016 2:22:29 AM • Haier HLH326BB... • Answered on Dec 01, 2016
Why is my screen flickering?
Sounds like back-light inverter bard fault. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/
5/15/2014 2:56:58 AM • Haier HLH326BB... • Answered on May 15, 2014
How to fix haier hlh326bb poping sound and picture flickering how to fix.
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis.
4/25/2014 6:20:58 PM • Haier HLH326BB... • Answered on Apr 25, 2014
Which video format support in haeir led tv
It supportsHDMI,Composite,S-Video,ComponentDVIVGAAt 1366x768
10/15/2013 8:43:44 AM • Haier HLH326BB... • Answered on Oct 15, 2013
0answers
My haier tv backlight keeps flickering
Either the buttons on the TV or Remote are jammed. Just remove the batteries from the remote and see whether it still flickers. If yes, the problem is dust collection inside the TV panel buttons/switches. Might require thorough vacuum cleaning, after switching off the TV and removing the plug from the power outlet. If it still does not help, this might require attention by a qualified service technician
7/11/2012 6:20:18 AM • Haier HLH326BB... • Answered on Jul 11, 2012
Picture is flickering. connections to
try plugging the cable from the wall into the back of the t.v. and see if you have basic cable. usualy it will be channels 2-74 depending on the provider. you could also try using a different connection like HDMI or S-video or component
8/13/2011 7:44:00 PM • Haier HLH326BB... • Answered on Aug 13, 2011
Can I remove the stand
Depending on the production serie and the country in which it was sold the bolts that secure the foot stand are at the rear of it (4 of it) or at the bottom - 2 of them - you will have to put the tv flat down on a table to access them.
6/20/2011 2:11:38 PM • Haier HLH326BB... • Answered on Jun 20, 2011
I broke the table top
If it is not practical to glue the base back together with metal-filled epoxy (e. g., J-B Weld), then consider whether you can adapt the hardware to a custom wood base. If you are not comfortable with your woodworking skills, any cabinet shop could probably make a base for you. Be sure to include space for the base weight in the bottom of the wood plate, and specify that it must be capable of supporting the set. (The entire weight of the set including the original stand is 50.7 pounds; subtract the weight of the stand to find the minimum support capacity.) If the vertical arm broke, it may be better to replace it with steel or aluminum channel or tubing.
If the original stand mount scheme is not amenable to a hardwood base, you can build a stand to use the wall mount holes in the back. Be sure to offset the base weight forward enough so the weight of the mounting bracket doesn't tend to tip the set backwards.
5/24/2011 11:27:11 PM • Haier HLH326BB... • Answered on May 24, 2011
2answers
Can not turn off tv, have tried manual and remote
Hello, there are three options for such failure, the first and simplest is to try to get the remote control out of the room while the TV is off when it is in stand bye. A second possibility is the micro switches in front of the TV, you can verify that they cause failure by disconnecting the cable that connects them to the main board. If the problem stops, you will need to replace all the front switches. And now the last option, however the more expensive one, that there is a malfunction of the micro-processor circuit, from which comes the command to turn on the TV. I hope that was helpful! Please come back to me, if you have any questions or if you need further guidance.
2/28/2011 8:35:13 AM • Haier HLH326BB... • Answered on Feb 28, 2011
How do i restore factory
To begin with, this is an internal failure. You could unplug the TV for few minutes, say 15 minutes, and then turn it on. If the problem persists, then you need to get the TV repair. Restore / reset would not help at all.If you have the electronic repair experience, could read schematics and would be able to keep all precautions, i would be glad to provide you with a link to purchase service manual ( as you need to have the exact values of the components ) and i would be glad to provide you some pointers.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
9/18/2010 8:39:03 AM • Haier HLH326BB... • Answered on Sep 18, 2010
Has a ghost image in the same spot no matter if
yes u should get a tec but will prob b told 2 better buyin a new tv
2/18/2010 11:21:20 AM • Haier HLH326BB... • Answered on Feb 18, 2010
Need the plug to a Haier 32 inch tv
does it look like this?
http://ecx.images-amazon.com/images/I/41CQY0FD16L._SL500_AA280_.jpg
if so send me an E-mail [email protected] $4 for a new cable about $3 fr shipping. Also id thats not the cable I most likely have 1 if you can send me a picture of the receptacle on the back of your TV.
http://www.RNS-Systems.com
10/17/2009 11:08:24 AM • Haier HLH326BB... • Answered on Oct 17, 2009
0answers
Haier HLH326BB 32 in. LCD HDTV Logo
37 questions posted
Top Haier Televison & Video Experts
Kolbrun...
Paul Bade
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
HL Haier
  • HL Haier
Most Popular Question
picture flickering connections
  • Televison & Video
