20 Most Recent Konka KDL-37AT23U Television Questions & Answers
you can connect it via component cables *red blue and green* for video and red and white for audio or yellow (video) red and white (audio) (rca cables) that came with the wii as well as hdmi to your inputs in the back of the tv.
Konka... • Answered on Mar 26, 2011
are you using an hdmi cable to the tv?
Konka... • Answered on Jun 25, 2009
try connecting thru an hdmi cable from your dvd player to your tv, check the colors then.. I'd say you have crossed your component cables.. match the connector letters a/b/x? and plug them in one after each other.
Konka... • Answered on Nov 30, 2008
do you have speaker on the top? if yes , change the place and good view screen, p.s. sorry for my english, thank .
Konka... • Answered on Feb 11, 2008
Have you tried the "KMC" code (should be 219). KMC is Konica Minolta who used to make Konka TVs. Here is the link to the programming instructions and all the codes if you need; http://optimum.custhelp.com/cgi-bin/optimum.cfg/php/enduser/std_adp.php?p_faqid=1420 If that code doesn't work, then apparently philips codes may work for your model (164, 005, 038, 093, 127, 070, 003, 004, 059, 236, 238, 243, 247, 199) (sorry you have to work through them one at a time). Hope the KMC one works :)
Konka... • Answered on Aug 21, 2007
Corrupted firmware. A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Konka Televison... • Answered 3 days ago
SOLVED: My konka smart tv is stuck on smart tv loading ...
www.fixya.com > Forum > Televison & Video > Konka
May 27, 2018 - my konka smart tv is stuck on smart tv loading doesnt go further - Televison & Video. ... check the site linked here. Pull up older posts. ... My TV Konka LED TV KDL55XS712AN is not starting and saying: LOADING... Corrupted ...
How to perform a Forced Factory Reset on an Android TV ...
www.youtube.com > watch Jun 8, 2017 - Up next · Sony Smart TV: How to HARD FACTORY RESET without Remote (Use Buttons on TV) · How To Run Through A Power Reset On Your TV.
Konka LED TV KDL55S712AN has refused to start and is ...
www.justanswer.com > ... > Smart TV Problems
Sep 2, 2016 - Konka LED TV KDL55S712AN has refused to start and is staying in the screen on" Smart TV loading..." ... Then on the actual TV, hold the power button for 60 seconds then release. Then wait 10 minutes, connect the power again to the TV, turn it on and tell me please if it is now operating correctly. 1 answer
Android Stuck On Boot Screen and How To Fix It ' Wirefly
www.wirefly.com > guides > android-stuck-on-boot-scr...
Restart The Device. This is the first step in troubleshooting an Android device that won't boot past the startup screen. If this has not been done, it ... ..
Konka Televison... • Answered on Jan 31, 2021
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done. NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important. Type in the brand name only to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Konka Televison... • Answered on Apr 23, 2020
Sounds like firmware corrupted. An update might be necessary. Just do a reset before that. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Konka Televison... • Answered on Jan 11, 2020
Konka KDL-37AT23U Television Logo
Popular Tags
14 questions posted
Top Konka Televison & Video Experts
Paul Bade
Marvin
Marvin
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Konka Televison & Video
Most Popular Question
new wii s only showing up in
  • Televison & Video
