20 Most Recent
Champion 3500/4000 Watt Portable Generator Questions & Answers
My Champion 4000 watt generator will not start in cold weather
If you want it to start with a start motor, driven from a battery, my guess is the battery is in bad condition. Normally a battery will perform less when temperature is going down, but an old or worn out battery can't perform at all when it is cold. I would check that first. Just take a good battery to start one of them and see what happens. Then see if you want to replace them.
11/22/2014 10:27:13 PM •
Champion...
Answered
on Nov 22, 2014
Champion 3500 generator how to fix stuck float
It could be a carburetor problem or it may be the low oil cut off switch. Check to make sure oil level is up. If it is check the needle valve attached to the float and the seat. The old carbs used to have a brass seat. Some of the new carbs have a rubber seat and it may need to be replaced. Hope this helps.
12/31/2013 9:25:42 PM •
Champion...
Answered
on Dec 31, 2013
