20 Most Recent
Toshiba Satellite p105-S6114 Notebook Questions & Answers
How do i resart my
Quite simply, you cant. You would normally do this by inserting the original recovery disc in the cd drive and press F12 as you turn it on.
The only options available are asking Toshiba for the discs (for which they might charge) or see if you can find someone with the same machine and borrow theirs.
12/22/2010 11:54:10 PM •
Toshiba...
Answered
on Dec 22, 2010
I have a Toshiba Satelliet
open cd rom door just clean lense with soft cloth ...if same
remove cd rom romove top cover then romove buttom u can see on back of lense two veriable for lense adjustment try one by one one adjustment is for normal cd and one is for dvd cd dont try together.. move little bit...and clsoe and then check... Thanks
9/14/2010 7:33:48 PM •
Toshiba...
Answered
on Sep 14, 2010
I would like to scratch-install the new WINDOWS 7
ecommended Windows 7 Installation Method SelectionToshiba
provides support for installing Windows 7 on laptops built since 2007.
Depending on your model, Toshiba recommends using one of the following
software tools as part of the Windows 7 installation process, to
support ongoing use of Toshiba provided features and functionality:
- Toshiba Upgrade Assistant for Windows 7, for upgrading from Windows Vista to Windows 7 on laptops made in 2009
- Toshiba
Software Installer for Windows 7, for performing a Custom Installation
of Windows 7 ("clean install") on laptops made 2007-2009
Find
your laptop's serial number on a sticker on the bottom of the laptop,
note the second character in that serial number, then click on the
matching link in the list below for instructions on Toshiba's
recommended Windows 7 installation method for your model.
For all laptops made since January 1, 2007*When upgrading from Windows Vista (not a Custom or "clean" Install)
- if the second character of your laptop's serial number is 7 or 8, click here.
- if the second character of your laptop's serial number is 9, click here.
When upgrading from Windows XP, or doing a Custom Install ("clean install") from any operating system
- if the second character of your laptop's serial number is 7, 8, or 9, click here.
- if the second character of your laptop's serial number is not 7, 8, or 9 then it was manufactured prior to 2007.*
* Installation of Windows 7 is not supported by Toshiba for laptops made prior to 2007.
Hope it helped.
11/21/2009 1:44:35 PM •
Toshiba...
Answered
on Nov 21, 2009
I have a Toshiba satelite P105-s6114 and it is
Passwords are designed to keep people out!
default meants the password that was set by the owner. Initially there is no password. So someone has set one up.
The person who put the password in is the one who can open it. Sorry
9/5/2009 6:17:16 AM •
Toshiba...
Answered
on Sep 05, 2009
My toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video
cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external
monitor to your laptop's video-out, and then swap your monitor view to
'both' or mirrored (usually just the function key (FN), plus one of the
Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external
monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
8/21/2009 9:36:11 PM •
Toshiba...
Answered
on Aug 21, 2009
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
How can a fix error code oxcoooooof
Just restore your system from a backup taken before the error code started.
If you have no backup then you need to format your hard disk and do a complete reinstall of all your software.
3/19/2020 10:52:50 AM •
Toshiba...
Answered
on Mar 19, 2020
How to play a DVD on Toshiba Satellite Pro C850
If you know the DVD and the DVD drive is in proper working order, it could mean that the software you are running just may have some problems. Try downloading a copy of VLC (VideoLan Client) this application is free and open source (and no it's not something I created and am just trying to get people to use...it's just something that works great, and completely free) VLC can play almost any video file or DVD that it encounters. If VLC can't play it, I would think it's likely there may be something with your disk or your DVD drive.
3/11/2020 8:58:46 AM •
Toshiba...
Answered
on Mar 11, 2020
