20 Most Recent Olympus FE-180 Digital Camera Questions & Answers
Have you tried replacing the card with a blank one, so there is space for the camera to move images to ?
Olympus FE-180... | Answered on Jul 07, 2016
As long as the xD card was not formatted it is possible to recover the images that were accidently erased,lost or corrupted. You can go to the following website link and download an image recovery software program that is free of charge.
http://www.z-a-recovery.com/
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and many people have had much success in recovering lost images.
Data recovery is a booming industry, and many appropriate services and software can be found by searching regional phone and business directories or the Internet for terms such as "image recovery" or "data recovery".
Olympus FE-180... | Answered on Oct 06, 2012
FAULTY OR ITS NOT WEATHER PROOF
Olympus FE-180... | Answered on Sep 08, 2012
ya dude here is the sol yr camra is ok but mem crd is suffring frm tech prob.so, insert it tinto anew cam and try.sure it will or master rset yr settings frm menu gud luck
Olympus FE-180... | Answered on Apr 18, 2011
If you are able to take good photo's through the view finder, then it indicates the LCD screen is damaged and will need to be replaced.
Olympus FE-180... | Answered on Mar 07, 2011
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Olympus FE-180... | Answered on Feb 06, 2011
Easiest way...use a separate card reader and just drag and drop the ones you want. typrice_43.jpg
Olympus FE-180... | Answered on Dec 09, 2010
mine got the same problem dont know what to do!!!
Olympus FE-180... | Answered on May 14, 2010
Olympus FE-180... | Answered on Mar 16, 2010
It seems there is some problem with Memory Card, So, two option will be there:-
1 )Try to Format the memory card.
2) Replace /change new one.
Note:- Formatting the memory card erase all the data including protected images and other file types. So, once you formatted the memory card there is no way to restore them.
Rating the solution is highly appreciated....Good Luck
Olympus FE-180... | Answered on Mar 03, 2010
There is no driver available for this model of camera if you use Vista or Windows 7 then you can try the steps below..
Connect the cam with the PC
If there is a inbuilt driver in windows then the cam will be installed automatically.
Open "Computer" from Desktop then look for the camera name after the drives names or look for any new drive named removable drive.
Open that drive to download the pictures from the cam to the PC.
Olympus FE-180... | Answered on Feb 28, 2010
Secure Digital cards have a write-protect switch.
Turn off the camera.
Remove the memory card.
Find the switch along one edge. It needs to be closest to the contacts in order to enable writing. For best results, slide it fully away from the contacts and then back fully toward the contacts.
Reinsert the card.
Turn on the camera.
If that doesn't work, try a different card.
And if that doesn't work, then there may be a problem with the camera itself.
Olympus FE-180... | Answered on Jan 20, 2010
go into the setup menu and turn off "Write Protect."
Olympus FE-180... | Answered on Oct 09, 2009
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.http://olympusamerica.com/cpg_section/cpg_servicerepair.aspOlympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $75 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Olympus FE-180... | Answered on Jun 10, 2009
if you love your camara bring it to a olympus dealer and ask them to check what the repair costs would be than uyou can decide to try it your self, buy a new one or let it be fixed.
Sand is always dangerous , it can come to vital parts where you don't want it to be.
cleaning yourself:
especially do not use a vacuum cleaner to suk the sand out, but , use enough light, a pair of steady hands, a box to fit in the screws (make a drawing witch srews where when) and take the time, use inside only a clean painters brush (thin) and wipe out any sand that can be seen, from the optics. than after cleaning assemble it in the reverse order of the disassembly , put all the srews in their place tighten them hand vast (not with a electroic tool but only by light force ) vast is vast (meaning it should use a light force to open the screw) and preferably use a dust free environment (rent a baby's box like in the hospitals used for very young childern)
but my advise would be advise nr 1: bring it back to the dealers
Olympus FE-180... | Answered on May 11, 2009
Olympus FE-180 Digital Camera Logo
35 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
FE Olympus
  • FE Olympus
Most Popular Question
get camera delete photos see below get
  • Cameras
