20 Most Recent Kodak EasyShare C433 Digital Camera Questions & Answers
See if it is the power savings settings in the menu. If you select maximum saving (or similar) the camera keeps the screen off so not to use more power
Kodak EasyShare... | Answered on Oct 02, 2015
just watch the video for different methods on how to transfer pictures from camers to the computer
Kodak EasyShare... | Answered on Nov 19, 2014
Next to the battery. It could be the slot is empty, but then you know where to put it.
Be aware you only can use MMC (old) and SD cards, so don't try SDHC cards or even SDXC cards. They won't work in your camera.
Kodak EasyShare... | Answered on Jul 07, 2014
You don't need any special software to use your camera.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa ( http://picasa.google.com ).
Kodak EasyShare... | Answered on Dec 03, 2013
Hi mate,
As far as this camera is concerned, the videos are being recorded in .MOV format which is standard in these type of digital cameras. Install QuickTime player or KM Player, you can Google and get these players. They play these videos perfectly with audio and video as well.
Hope this helps. If you like it, please leave me a rating.
Cheers.
Kodak EasyShare... | Answered on Nov 03, 2013
Try a firmware reinstall from the Kodak website for this model, if this does not help it is repair time.
Kodak EasyShare... | Answered on Jan 24, 2013
My Kodak Easy Share C433 camera does the same thing! Does anyone have a solution?
"camera turns on..sometimes turns off again...if lucky will take a picture before it turns off again.. the battery is flashing even though I have just changed them"
Kodak EasyShare... | Answered on Aug 22, 2012
You may have to connect to a computer then disconnect it from the computer safely(click on safe removal icon in the tray)?
Kodak EasyShare... | Answered on Feb 16, 2012
Its LCD is directly connected with chip LS7408 which is unable to maintans its current stat in case of any jitter so you have to change that chip
Kodak EasyShare... | Answered on Oct 04, 2011
That's your decision. Alkalines are the cheapest. Lithiums will last longer but cost more. Rechargeables won't last as long per charge but they can be reused.
If you're going on vacation, you might want lithiums. If you're staying close to home, you might want rechargeables you can charge up every night. No matter what you do, you'll probably want a set of spares just in case, just as you'll also want a spare memory card.
Kodak EasyShare... | Answered on Jul 26, 2011
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Kodak EasyShare... | Answered on Mar 04, 2011
The chargeable batteries are best for the digital camera, I recommend Sony, or Panasonic.
Kodak EasyShare... | Answered on Jan 12, 2011
I have the same issue. Reading the responses on this site, I gather that it is because of faulty batteries. I have been adviced by the GURU to use Panasonic or Sony chargable Batteries. If that does not work - call Kodak customer service.
Try one or more of the following:
  • Insert a charged battery/batteries.
  • Press the shutter/record button all the way down.
  • Transfer all pictures/videos to the computer, delete the copies on the camera, or insert another memory card.
See your User Guide for more information.
To conserve battery power, some cameras switch to a power-save or sleep mode after a few minutes of non-use. If your camera is sleeping, press any button to wake it up. For further instructions, see your camera User Guide or Extended User Guide at KODAK Product Manuals.
Then try to take a picture or video.
  1. If your camera is on, turn it off.
  2. Wait 10 seconds, then turn on your camera.
  3. Take a picture/video.
Kodak EasyShare... | Answered on Jan 01, 2011
Having gone over a month with no response to my query, I assume it was a SD/SDHC mismatch.
Kodak EasyShare... | Answered on Oct 06, 2010
You can blame windows updates. Use a card reader from now on to make your life easier.
Kodak EasyShare... | Answered on Jun 04, 2010
It is not possible to buy a viewing screen for KODAK cameras.
If the camera has been dropped KODAK will determine this fault as Out of Warranty
An Out of Warranty repair for this model for this fault is about 48 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
In order to arrange your repair/Trade up: Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Kodak EasyShare... | Answered on Jan 21, 2010
Kodak EasyShare C433 Digital Camera Logo
45 questions posted
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
horizontal lines going across screen
  • Cameras
