20 Most Recent
Nokia E50 Questions & Answers
How to i connect my nokia e5 to wifii
Hi there
Select Menu > Ctrl. panel > Connectivity > WLAN wiz..
The WLAN wizard helps you to connect to a wireless LAN (WLAN) and manage your WLAN connections.
If the search finds WLANs, to create an internet access point (IAP) for a connection and start the web browser using this IAP, select the connection and Start web browsing.
If you select a secured WLAN, you are asked to enter the relevant password. To connect to a hidden network, you must enter the correct network name (service set identifier, SSID).
I also found the full manual in pdf format which you can download from here
http://nds1.webapps.microsoft.com/phones/files/guides/Nokia_E5-00_UG_en.pdf
Good luck
11/11/2014 2:37:55 PM •
Nokia E50
Answered
on Nov 11, 2014
My phone has its lock code and i forgot so i cant restore my nokia e5
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
4/14/2014 4:32:58 PM •
Nokia E50
Answered
on Apr 14, 2014
How to format nokia e50
Hi, you can format your phone by pressing a combination of 3 keys - green key (Call answer button), star key (* key) and key number 3 simultaneously while powering on your Nokia E50.
Note : All data will be lost on the phone and it will revert to factory default.
3/31/2013 4:17:48 PM •
Nokia E50
Answered
on Mar 31, 2013
I forget my lock code, imei - 351892015152106
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
1/18/2013 3:17:57 PM •
Nokia E50
Answered
on Jan 18, 2013
