20 Most Recent Olympus Stylus 730 Digital Camera Questions & Answers
2answers
Retrieving my pictures from camera wen i pressed format
there is a lot of recover software on the internet, here is one you can use, and the free version is ok : https://www.piriform.com/recuva/download othervise try to look here on google search : https://www.google.dk/webhp?sourceid=chrome-instant&ion=1&espv=2&es_th=1&ie=UTF-8#q=undelete hope it helps or return here...
6/13/2014 2:22:31 AM • Olympus Stylus... • Answered on Jun 13, 2014
'Zoom error' rubbing lens
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
6/7/2011 1:41:30 PM • Olympus Stylus... • Answered on Jun 07, 2011
My lcd screen goes to a white after i power up
Somehow you might have damaged the screen on the inside of the camera. you might want to get it looked at or send it in to the company. if you have a warranty you might want to take it out on your camera.
5/5/2011 12:45:57 PM • Olympus Stylus... • Answered on May 05, 2011
When I "power' on camera,
Looks like the camera lens is trying to adjust, and gets stuck due to a mechanical defect. The only safe way is to return it or send it to manufacturer if it is under the warranty. Only a camera technician can fix this.
If it is not possible to return, or if it is not under a warranty, and if you dont want to spend money for a technician to fix it, and you really want to take the risk, there are a few suggestions from people using this camera on this website facing this issue. Click on this LINK. You may use these if you really have no other option at your own risk.
Hope this helps.
4/12/2011 5:40:06 PM • Olympus Stylus... • Answered on Apr 12, 2011
Will not load to windows
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
4/12/2011 5:18:10 PM • Olympus Stylus... • Answered on Apr 12, 2011
I have a 1 GB Olympus xD Picture Card that I am
Formatting won't make it any easier for any recovery program to find the photos, so I definitely wouldn't do it, but leave the card as it is until you've successfully recovered them. In my opinion, the best program to use is called PhotoRec and you can find it here. It's free, released under the GNU licence. (Be sure to save any photos you recover to your computer... not to the card itself.) If that fails, then move on to try paid programs if you wish.
After you've recovered all the photos that you're going to get, only THEN would I format the card (in the camera please) in order to re-use it.
3/23/2011 6:57:33 AM • Olympus Stylus... • Answered on Mar 23, 2011
My date is set on my camera but when I print my
That depends on the program you're using. Depending on the program (and printer), you can print the date on the image, in the margins, or on the back. Please refer to the documentation for whatever program you're using.
3/10/2011 11:19:45 PM • Olympus Stylus... • Answered on Mar 10, 2011
Olympus stylus 730 zoom error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Regards
Andrea
2/6/2011 8:05:15 PM • Olympus Stylus... • Answered on Feb 06, 2011
When I go to turn
Make sure that the battery is fully charged and hols a good charge on it . This is very important as the fault relates to a poor charge or poor battery charge retaining. If you have confirmed that the battery does have a good charge present , the check the terminals for any crusting/erosion . If so use a good cleaner to wipe off the crusts and polish the terminals.
Now set the battery and try to put the camera to a manual mode- disabling the flash. If the camera works then the flash unit can be short and is draining the battery. If not the camera has some regulator in the circuit it can be short.
2/5/2011 7:31:50 AM • Olympus Stylus... • Answered on Feb 05, 2011
Hi, I have an olympus u730 all weather 7.1
Unfortunately, the software is not provided by the manufacturer for download.
But, you can transfer the pictures to the computer without using the software. For detailed steps, please refer to the attached images:
You can then view and copy the files by double-clicking the "Removable Disk" icon in My Computer
Alternate Method:
You can download pictures from your camera to your computer by using a memory card reader (You can use your computer's built-in memory card reader, if it has one, or you can purchase an external memory card reader as shown in the attached image).
To do this, kindly remove the memory card from the camera and insert it into a card reader. Connect the card reader to the USB port of your PC (if you are using an external card reader).
Now, the memory card will be shown as a "Removable disk" in "My Computer". You can browse the images and copy the images to your computer.
Hope this solves your problem. Thanks for using FixYa.
2/2/2011 11:00:14 AM • Olympus Stylus... • Answered on Feb 02, 2011
Reads zoom error when turned on
The device requires restoration achieved in two processes
perform a check
1. Power off completely the camera.
2. Remove all power devices or batteries
3. Check the entire device for damages
4. Make observation notes about any malfunct features
5. Replace batteries and removeavble parts properly with caution that every feature is intact.
6.If the device still displays error message consider the second phase explained
a. The device program features are jammed only possible solution is performing a software update or upgrade
1. updates are achieved by contacting the device;s technical support deparment
2. Upgrades can be performed by acquiring an installation kit in which instance requires technical expertise to perform an intergration restoration
Important notes
1. Apart from the message received does the device malfunction?
2. Your camera would be displaying an image similar as flash screen or screen saver that can be fixed quiet easily
a. use the menu buttons to select the option of settings
b. set the picture to be displayed on the appears screen area once powered on.
c. Possibly alter the entire image displayed as desired by yourself.
4. A screen saver could only be deleted,, hidden, or replaced with a preferable image
5. Possibly, the words ZOOM ERROR could changed to WELCOME TO OLYMPUS STYLUS
Refer to the camera manual for diagnostic support
12/2/2010 6:49:27 AM • Olympus Stylus... • Answered on Dec 02, 2010
Zoom Error in my camera olympus M 730
Hello
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
Regards
Andrea
9/30/2010 12:39:03 PM • Olympus Stylus... • Answered on Sep 30, 2010
Shows zoom error an shutdown olympus stylus 730
Hello
Regards
Andrea
9/30/2010 11:28:59 AM • Olympus Stylus... • Answered on Sep 30, 2010
At start up zoom error
Hello
Regards
Andrea
9/27/2010 5:03:15 PM • Olympus Stylus... • Answered on Sep 27, 2010
I have never had a
Please download and install these two programs to the computer, after you have done so, the video should play back normally, and so should all if not most videos that you can find.
First, install FFDSHOW video decoder. Here is a link to the setup file http://www.free-codecs.com/download_soft.php?d=5550&s=50
installing the decoder is simple, simply click next next and next until the setup ends, then close or finish, you don't need to many any changes into its settings, after its installed it will work on the background when ever a video is played.
Next you need to install VLC media player, its a versitile media player that plays almost anything. You can get it from here http://www.videolan.org/vlc/ - download VLC
After you have installed both, start VLC and open the video file in it, it should play normally, you should have picture and sound.
Let me know if you still have trouble playing video files.
9/21/2010 6:13:17 PM • Olympus Stylus... • Answered on Sep 21, 2010
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Regards
Andrea
8/14/2010 6:45:21 AM • Olympus Stylus... • Answered on Aug 14, 2010
I need a user manual for olympus u730 to use this
You can download the basic manual in PDF format by clicking this link.
To download the Advanced user manual, click here
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
6/28/2010 1:38:38 PM • Olympus Stylus... • Answered on Jun 28, 2010
Camera died while taking pictures. Lens is open.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
5/4/2010 1:37:18 PM • Olympus Stylus... • Answered on May 04, 2010
Olympus Stylus 730 Digital Camera Logo
46 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Stylus Olympus
  • Stylus Olympus
Most Popular Question
shows zoom error shutdown olympus stylus
  • Cameras
