20 Most Recent
Nikon COOLPIX S9 Digital Camera Questions & Answers
Cannot download pictures with data cable
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
My coolpix s9 cam will not transfer pics from
You can copy pictures from the internal memory to a memory card by selecting "Copy" from the Playback menu.
Press the MENU button to bring up the main menu, then select the right-pointing triangle to get into the Playback menu.
I AM HAVING A PROBLEM
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
I am getting an error
If you really want to transfer your pictures from your camera to your computer, with a cable, then reinstall the Cd provided with the camera, that should fix the problem.
But in any case the best way to transfer what's on the camera is to take the memoy card out and plug it inside a card reader on your computer. You can buy one for less than 30$ if you don't have it on your computer.
Transfering the pictures this way is much faster, and it saves your camera's battery
All the pictures on my
PictureProject was retired quite some time ago, replaced by Nikon Transfer and Nikon ViewNX. You can download the current versions of all (free) Nikon software from
You might want to consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Nikon Transfer or any other photo cataloging program.
Nikon CoolPix S9
Good day,<br /><br />It sometimes happen that you lose your cameras user manual.<br />This can be very frustrating as you need to look up something, but you can't seem to find a manual anywhere!<br /><br />Well if you follow <a href="http://www.retrevo.com/s/Nikon-S9-Digital-Cameras-review-manual/id/564ag816/t/1-2/">THIS </a>link you can download your cameras user manual on your computer and thus keep a digital copy handy for all the times you need it.<br /><br />Please let me know if this information was helpful!<br /><br />Kind Regards
Nikon Coolpix s9
Do you really want to download your pictures this way? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. You can also use software such as Nikon Transfer and Nikon ViewNX to transfer and organize your pictures. You can get the current versions of Nikon software from http://support.nikontech.com/app/answers/detail/a_id/61
My nikon s9 suddenly blacked out
Does it take the picture? I mean, after you try to photograph something, can you download a good photo?
If yes you probably deactivated the display. Check the manual to see how to turn it on again.
If not, it's probably a software error, and you need to go to a local Nikon dealer
Lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Urgent: card cannot be used
It may be of a type incompatible with the camera card reader. It is also possible that the card has a higher capacity than the camera microcode (firmware) is able to access. Check the manufacturer website to see if a recent firmware has enabled access to bigger capacity cards.
There is also the possibility of wrong format. Most cards are FAT or FAT32 to make them accessible by most computers, but you can never know.
Hope it helps
