20 Most Recent
LG 32cs460 32" Inch Widescreen 720p 60hz Lcd Hdtv Television Questions & Answers
LG 32CS460 Lost freeview after cable unplugged
Check the cable connectors and the connectors on the wall and TV to make sure the cat didn't break any of them. (It seems odd that a cat would be able to pull a coax connector loose - maybe antenna cables in the UK aren't threaded as they are in the U. S. A.).
No picture, no sound
see the troubleshooting index:God bless you
No sound
1. Check if the TV and Amplifier (if
connected) is turned on and set correctly.
2. Check if the TV, DVD player and
Amplifier are connected properly.
3. Make sure the TV, DVD player and
Amplifier volume are not set to
Mute.
4. There will be no sound output
during
Reverse Play /
Pause /
Step /
Slow /
Search.
5. If the DTS soundtrack is enabled
in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will
not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc
Menu.
Does not
play disc
- No disc. - Load a disc into
the tray.
- Disc has been loaded upside
down. Place the disc with the label side up.
- Disc region code does not
match region code of the player.
- Disc type is not the correct
type to play.
- Disc is damaged or dirty.
Clean the disc or try another.
- Moisture may be condensed
inside the unit. Remove the disc and the leave the power on for one or
two hours.
How do I find for DVD BD370 the Multiregion code
Please follow the steps
1.Download http://www.multi-region.net/_media/6000.zip
2.Extract the files
3.Burn the directory RMTM0000 to a CD-R
4.Write mode: ISO format, Mode 1, ISO 9660.
5.Put the CD-R into the player
6.When the Region Management System screen is displayed, set the Region Code to “0” using your remote.
7.Press PAUSE
8.Your are done
Thanx
