I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV
up(warranty was up of course) and found several bad capacitors.
Phillips and several other companies were sold capacitors that although
were highly rated failed within 5 years because of a lack of
preservatives. All sorts of electronic equipment is now being effected
due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
If the door will not open, take a small paper clip and unwind it so you have a straight part about 1-2" long. Look at the DVD door and see if there is a small hole. If you see one, put the paperclip in there and press a bit to see if it will open the door a littlw. If it does, you may need to use a non-metallic popcycle stick or similar to get the dvd into a position where the door will open all the way so you can extract it.
Hi, It sounds tv does not have back light to show picture in lcd and possible cause is back light inverter board. Please check bright white light coming from any vent holes at rear of tv? Does tv show any screen display or any kind of light in screen? Is it Toshiba 32HLV66 lcd tv or any other model. Let me know to diagnose problem.
Try the main board with the cpu chip. The cpu chip should have a heatsink attached to it, may be an overheating problem. It has the LCD panel connector plugged into it. You may be able to find the board on ebay for less than a repair shop.
This is a known issue with this TV. The following might resolve it:
Check Mute and Volume:
Ensure that the TV is not muted and that the volume is set appropriately. Sometimes accidental button presses can lead to muted sound or low volume.
Inspect External Speakers:
If you're using external speakers, verify their connections. Loose cables or faulty speakers can cause sound issues.
Test Different Inputs:
Connect a non-HDMI device (such as a DVD player) to the TV. Observe if the sound distortion occurs. If it doesn't, the problem might be related to the HDMI signal from your Virgin box.
HDMI Troubleshooting:
If the issue persists with the DVD player over HDMI, consider the following:
HDMI Cable: Check the HDMI cable for damage or loose connections.
Virgin Signal: Contact Virgin to inspect the signal/lines and replace the box if necessary.
Mainboard Replacement (if needed):
If the sound distortion persists, it could be due to a faulty sound processor chip on the TV's mainboard. In this case, consider replacing the mainboard.
TOSHIBA 42RV500E, 42RV500T, 42RV500Y, 46RV500E, 46RV500T User Guide (manualmachine.com)
There may be loose contact or track open in main board.So try to check the main board thoroughly where you may find the loose of connection or track open.
Locate the Battery Cover: Look for the battery cover on the back of the remote control. It is usually a small compartment that can be easily opened.
Remove the Battery Cover: Depending on the design, there may be a latch, screw, or sliding mechanism to secure the battery cover. Use your fingers or a small screwdriver to open the compartment.
Remove Old Batteries: Take out the old batteries from the battery compartment. Pay attention to the orientation of the batteries, so you know how to insert the new ones correctly.
Check Battery Polarity: Take note of the positive (+) and negative (-) signs inside the battery compartment. Make sure to insert the new batteries with the correct polarity to match these markings.
Insert New Batteries: Place the new batteries into the battery compartment, ensuring they are properly aligned with the correct polarity. Press them down gently to make sure they are secure.
Replace Battery Cover: After inserting the new batteries, close the battery compartment cover securely. If it has a latch or screw, make sure it is fastened properly.
Test the Remote: Point the remote at the device it controls (such as a Toshiba TV) and test whether it responds to your commands. If the remote is working correctly, you have successfully replaced the batteries.
Dispose of Old Batteries: If the old batteries are no longer usable, make sure to dispose of them properly. Many communities have designated recycling locations for batteries.
Serial numbers don't work Judy
https://www.google.com/search?q=A10A13799C3300
They are purely a numerical identifier of when it was made, year, day, number on the shift, whether it Joe or Billy who did final inspection.
With a MODEL number I can find them easily with just 'make model manual'.
Toshiba
http://www.toshiba.com > support > content
PDF
Thank you for purchasing this Toshiba LCD TV. This manual will help you use the many exciting features of your new LCD TV. Before operating your LCD TV, please.
62 pages
Toshiba
PDF
Thank you for purchasing this Toshiba LCD TV. This manual will help you use the many exciting features of your new LCD TV. Before operating your LCD TV, please ...
62 pages
No you can't the Insignia remote is for that model television only. Companies don't make their remotes so they operate other makes of televisions. Buy a Copy Remote for the Toshiba
https://www.google.com/search?q=insignia+remote+NS-RC03A-13
