there is a possibilty to recover deleted videos from Sony camcorders.
When you directly deleted videos from your camcorder, there is no
recycle bin thing as on a computer to store deleted files, and this's
why you can't see them when you connect it to your computer.
But deleted videos are not really gone, but it only become invisible
and is available to be overwritten by new files. Therefore, you can
recover any files from Sony camcorders like Sony Handycam, 3D camcorder
and more.download this camcorder recovery software named asoftech data recovery, you can download the data recovery software for free fromhttp://www.asoftech.com/articles/free-data-recovery-download.html
You may try a camcorder recovery software, recommended asoftech data recovery as it helped me before. use link below to download:Video recovery softwareYou may refer to this video tutorial
Hi.My name is Rick and I am the owner and technician of Discount Camera Repair. The problem you are experiencing can be repaired fairly inexpensively but will require disassembly by a qualified technician. If I can be of any help please call or email me. I'll be happy to repair the camera for you.
It's possible, but try to take no more videos until you've recovered your lost videos. This is to reduce the chance of you overwriting some of them. There are many good freeware photo recovery software options that may help you recover your photos. This article reviews and outlines several of the better ones.
If you cannot transfer your recording to your computer this could be because of several issues :-
Low disk space
Camera not properly connected to your computer
Incorrect method of copying files
The solution i would suggest to you is that :-
First , please connect your computer in the data storage mode , using the cable that you get with your camcorder.
Once connected , go to the directory where you would have all your files which have been recorded already.
Select those files that you want to copy by pressing CTRL key and clicking on each file that you want to copy and press ctrl + C key.
Then paste the file on your hardisk , you can create a folder on your desktop and put the files in it by using the paste command from the edit menu or by right clicking and choosing the paste option.
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
First you have check on tv is there same problem as you see on the camera LCD?
If no and only see on the camera LCD then there is one wire problem which is attached with Main board to lcd board.Its call flexable wire need to replaced this.
I had the same issue. I pressed and held various buttons and it apperently worked. This is exaclty what I did. Whether it is correct method or not, it resolved the vertical scrolling.
1- I had the camera siting in it cradle with the power cord connect to it. I pressed the tiny reset button
2- I pressed the easy mode and wide select buttons
3- I pressed and held the START/STOP button until it stopped scrolling. This seemed to reset everything and I had to reset the date and time which was no big deal.
This happens when the internal focus lens is off track, usually caused by impact and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repairedby a qualified service technician.
