20 Most Recent Samsung SyncMaster 940N Flat panel Monitor Questions & Answers
There is an option on the monitor to reset colour to factory default. Just bring up the on screen menu by pressing the left most button at the botton. Use the button next to this to highlight the colour settings which I think is the 5th or next to last option down. You will then see the option to reset colour and various other factory default settings. Happy computing
Samsung... | Answered on Apr 08, 2016
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Samsung... | Answered on Dec 14, 2014
Has a shadowing problem where everything on the screen was shadowing to the right. Did basic troubleshooting techniques and found that it was due to a loose connection to the computer. You may want to check this if resetting to factory settings doesn't help.
Samsung... | Answered on Jun 16, 2014
940N?
Samsung... | Answered on Apr 25, 2014
Your problem is usually caused by a bad power supply. You should be able to do the repair yourself, if just requires replacing 6 capacitors on the power supply board. Here is a link to a repair guide that shows how to disassemble the monitor and repair the power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is the a picture of the power supply board.
I hope this helps, if so please rate my solution.
BuddyMc
Samsung... | Answered on Oct 19, 2013
This is a known symptom of a failure in the power supply board. Here is a link to a repair guide that shows how to dis-assemble and the unit and then what to look for and replace on the power supply board to bring the unit back to working condition.
And here is a picture of the power supply board that needs to repair.
BuddyMc
Samsung... | Answered on Feb 26, 2012
This is a known symptom of a failed power supply board. Here is a repair guide for this unit that shows how to dis-assemble the unit and then what to look for and replace to rebuilt the power supply board and bring the monitor back to life.
And here is a picture of the power supply board.
I hope this helps you, if so please rate my solution.
BuddyMc
This problem is usually caused by a failure of the power supply board controlling the back lights. Here is a link to a repair guide with disassembly and repair instructions that should help you get the monitor back up and running again.
BuddyMc
You need to have the 3 capacitors. There is not a 2460uf capacitor, If one of the 3 fail then the other two will still work, if you have just one capacitor and it fails then you have a dead power supply with the first failure.
Buddy
Corporate Computer
www.ccl-la.com
Samsung... | Answered on Nov 28, 2011
They can be 1000uf 25v (20% higher value is OK), higher voltage is also OK but it may not fit the board. The temperature rating must be 105c and Low ESR type which is very important for switching power supply. You should replace them in a set.
You can get the PANASONIC FM or FC series from DIGIKEY, or from Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Samsung... | Answered on Aug 10, 2011
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Samsung... | Answered on Apr 05, 2011
Monitor this old will more likely to have bad DC filter caps by now, but you also may have failing LCD panel also. I would inspect the caps and voltages in the power supply section first.
You can failed SAMSUNG monitors due to bad caps in my albums.
You should read my guides also.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Samsung... | Answered on Jan 07, 2011
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Samsung... | Answered on Jan 04, 2011
i have the same problem, also looking for an answer....
Samsung... | Answered on Jun 17, 2010
It depends bad the parts are broken, this is 2007 model, you may have hard time getting replacement parts, details pictures will help.
Samsung... | Answered on Mar 29, 2010
Samsung SyncMaster 940N Flat panel Monitor Logo
52 questions posted
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SyncMaster Samsung
  • SyncMaster Samsung
Most Popular Question
remedy image disappears after minute
  • Computers & Internet
