20 Most Recent Samsung LNT5265FX 52 in. LCD Television Questions & Answers
No picture turns off after 15 min
Hello,This model is covered under the Samsung class action settlement. Samsung has agreed to pay for parts and labor on a group of TVs that had bad power supply boards and your model is one of them. You will need to contact Samsung to have the repair done, this is free to you. You can get full details here:http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
10/10/2019 6:31:27 AM • Samsung... • Answered on Oct 10, 2019
Purple dots on the screen
call samsung, probably bad capacitor needs to be replaced, mine was fixed for free even out of warranty. samsung arranged for in home service for free. Thanks Samsung.
3/11/2019 3:02:38 AM • Samsung... • Answered on Mar 11, 2019
Tv screen resolution
Check your menus. There should be one menu that allows you to resize the picture to the screen size. (Most likely a submenu in the video menu).
6/16/2017 5:41:34 AM • Samsung... • Answered on Jun 16, 2017
HDMI port not working
you can fix this by replacing the main pcb. I can get you a part number with the full model code and version number.
4/17/2014 11:24:59 PM • Samsung... • Answered on Apr 17, 2014
T-CON RIBBON CONNECTOR IS BAD
What is the model, serial, and version of your tv. I may be able to help you.
4/17/2014 10:52:24 PM • Samsung... • Answered on Apr 17, 2014
0answers
LNT5265FX/XAA
Be the first to answer 4/11/2014 4:18:12 AM • Samsung... • Posted on Apr 11, 2014Be the first to answer
T-CON RIBBON CONNECTOR BAD
Hi Saul try www.shopjimmy.com Len...
3/13/2014 4:30:05 PM • Samsung... • Answered on Mar 13, 2014
0answers
Samsung led tv has flickering
Flickering can be occurred to many reasons. If you wish to get more details, about this, check this site. From back-light to adjustments might cause this. http://electronicshelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
9/16/2013 7:20:55 AM • Samsung... • Answered on Sep 16, 2013
Fuzzy/Scramble screen when first turned on.
check solder joints on top of screen some screens were sub contracted to a chineese company called chi mai and had inherant defects
11/30/2012 9:33:24 PM • Samsung... • Answered on Nov 30, 2012
SAMSUNG LCD TV LNT5265FX, internal clicking but no picture for 1 minute at power up.
The set needs servicing, I would start with looking at the power supply
9/20/2012 4:33:37 PM • Samsung... • Answered on Sep 20, 2012
Samsung lnt5265fx hdmi ports not working
You may want to try a good, Monster Cable, HDMI cable.
9/3/2012 8:25:31 AM • Samsung... • Answered on Sep 03, 2012
2answers
Turn on tv and purple pixels like snow are spread around tv.
First thing replace any swollen capacitors in the power board.
12/24/2011 10:17:13 PM • Samsung... • Answered on Dec 24, 2011
3answers
Works fine for 1 or 2 weeks, but some times I try
There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance. The best way to check for loose connections is to tap lightly when the set is powered on, if there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, and use a good soldering iron to solder all suspected points. Sometimes the fault occurs when the set warms up; if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault. It can also be related to WEAK ELECTROLYTIC capacitors as the value can reduce in time.
10/20/2011 2:52:29 AM • Samsung... • Answered on Oct 20, 2011
My t.v. will not power
It's likely the power supply board. I had the same thing happen. I was able to open up the television and locate a couple of blown capacitors on the power supply board. The blown capacitors have a bulging end. When I identified this was the likely problem I was able purchase a kit online with all the replacement capacitors (about 10 total) , basic directions, a small bit of solder, and a solder wick. I only had to supply a solder iron and a screwdriver and replaced only the 2 bulging capacitors. It seamed to work for me. There are lots of videos on youtube and message that show people and discuss how to replace capacitors.If you find blown capacitors...here is where I got the parts. But I wouldn't buy the kit unless you see at least 1 blown capacitor. It might not work but you are only out $10 in parts if it works. http://www.karmtec.com/Search.aspx?Search=LNT5265FX
9/29/2011 7:46:10 AM • Samsung... • Answered on Sep 29, 2011
Samsung LNT5265FX 52 in. LCD Television Logo
47 questions posted
Marvin
Marvin
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
purple dots screen
  • Televison & Video
