20 Most Recent
RCA WSP155 Main / Stereo Speaker Questions & Answers
Rca 155 Wireless Speaker transmitter not working.
You probably have the polarity on your plug to the transmitter set on the wrong one. Set it to negative frequency, and it will probably work. I've had the same problem myself.
One other possibility: the Music has to be coming through for the light to go on, so if the music is too soft, you might not get any sound through. Good luck!
Can I buy a transmitter
open up your speakers and see if there is a slector for changing the channel. if there is you can change it to meet the requirements of your new transmitter
I need to purchase a
Radio Shack has the best selection.
I recommend the Enercellâ„¢ Universal 300mA AC Adapter
Model: 273-315 ' Catalog #: 273-315
Link to product page
HERE
The 300ma is the available power rating. It will be strong enough to power your RCA main unit.
You should bring the main unit to the store to match up the correct tip.
Just set it to 12V plus set the tip to the correct polarity and you are set to go.
RCA Wireless Speakers WSP 155
Hi, the following alternative may solve your problem:
Check to make sure the volume on the audio source is set to a normal volume.If the volume is too low, the transmitter will not turn on.
If it does not solve it, your system has a power problem in the power supply. Make checks on the regulator, it might have a open, if you are not a tech, let a tech take a look on your set to verify the damage component.
There is static coming out of my speakers on my
Don't worry, it's more possible that you have the static electricity and through your stereo this electricity goes to the ground. Try touching another metalic surfasce (refrigirator, oven etc), try to change your shoes (especialy if your stereo is on a carpet floor and you walk on it) Sometimes when we are very nervous the static electricity on our body is higher. So keep calm.
Stelios.
RCA Wireless speaker
This happened to one of ours, it turned out that the plug was damaged. Try using batteries and see if it will work, if so, you know that you need to just get a new adapter plug. Good luck!
Ac power adapter
Just use a universal adapter, put it on 12v, negative polarity.
Can't correctly connect speakers.
Just plug the transmitter into the headphone plug on the computer, tv, radio or whatever you're using, and then plug the transmitter & speakers into the walls. That's all!
RCA WSP155 wont play in all modes
My friend if you are using aux in tv or radio kindly check the connections into the receiver, and ensure that the cable system or antenna is connected directly into your receiver, and that you are using the tuner with the receiver, not the one on the TV. Also if you plug the wireless into the headphone jack try also to check the setting of your stereo to ensure that your main speakers neve shut off else it has something going on your setting configuration. Also you can try reconfigure and reset your settings in wireless to allign in your device using to ensure that all modes will play. Cause if you want to your wireless plays in all modes then the only you can do to make it work is by checking the connection of the receivers or you can edit and set your setting to adjust and work your wireless to a device you plug or connected with.
Hope this suggestion helps your problem.
If you need more assistance just reply to this post or contact me so that i can find new solution if this suggestion doesn't work.
If this solution works kindly rate this solution please. Thank you and godbless
Thanks.
Transmitter not working
You can 'pump up' the circuit on the transmitter by pumping the power connector in and out of of the back of the tranmitter to the beat of Beethoven's 5th: da duh duh duh, da duh duh duh, da Duh Duh.
It is a little awkward the first few times you try. You have to get the power connector in far enough each pump that the unit gets a pulse of power. It has to be pumped at the right pace, not too fast, not too slow, the beat of Beethoven's 5th is pretty quick and just right.
I have been powering our WSP155 transmitter unit on at work this way for several months. We originally had 4 sets of these, only using 1 transmitter at a time. 1 transmitter, 8 speakers. Over the course of a year or two, all of the tranmitters went bad the same way and now that I discovered how, I can make them all power on using this method, so I am pretty sure yours will power on this way too.
