20 Most Recent Lowrance iFINDER H2O C GPS Receiver Questions & Answers
Go to an electronic wholesaler. They sell all sorts of battery holders and parts that you can adapt.
Lowrance iFINDER... | Answered on Jun 21, 2016
My H2O don t recives the satelite s signal too, what can i do?
Lowrance iFINDER... | Answered on Sep 30, 2012
Your GPS is looking for an alternative source of NMEA data and is no longer doing it itself. If it doesn't get that data it will continue to look or wait for it. We can disable this function so the GPS relies solely on the data it is receiving through its own antanae. This function can only be changed while in Advanced mode. If you're not running in advanced mode make sure you switch to advanced mode. Once there, go to your Main Menu (from map screen, hit menu twice). In that menu, go and select SYSTEM SETUP. In your System Setup menu you will see an opition, COM PORT. Select COM PORT and hit Enter. You will see three Check boxes (NMEA INPUT, NMEA GPS INPUT, NMEA OUTPUT). Make sure that none of those are checked. Once you are done, you can EXIT out of the menus. Go out and see if you can acquire a Satellite Fix.
From:http://www.bruntonoutdoor.com/support.php?category=Atlas+MNS
Lowrance iFINDER... | Answered on Mar 24, 2012
If you burned the mother board, no, you'll have to get a new one, if its fused, you might be able to save it, if you are techie oriented, open it yourself and check for fuse, if theres visible marks of burning or charred on the board anywhere, then its gone....
Good luck.
Lowrance iFINDER... | Answered on Aug 23, 2011
Hello
Your GPS devices' bios IC has confused. It may be due to more external commands or by Bios software trouble. The only thing you can do with this device is, to reset it. To reset; do the following.
1. Press MENU'MENU'[Down] to SYSTEM SETUP'ENT'[Down] to RESET OPTIONS'ENT'<==
to YES'ENT.
In Easy Mode
Hold down the PAGES key while you press PWR to turn the unit on.
NOTE:
Reset Options does not erase any waypoints, routes, icons or plot trails.
Advanced Mode's Reset Options command (left)
and the Reset Options Menu (right).
If this does not help you, you have to update its software.
Lowrance iFINDER... | Answered on Jul 29, 2011
Hi try this link below
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/iFINDERHUNTc_0148-771_101905.pdf
Lowrance iFINDER... | Answered on Jan 27, 2011
Lowrance iFINDER  H2O C GPS Receiver Logo
20 questions posted
Top Lowrance GPS Experts
Marvin
Marvin
Harrie
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
View Most Popular
iFINDER Lowrance
  • iFINDER Lowrance
Most Popular Question
broken battery tab fixed
  • GPS
