20 Most Recent Sybase InfoMaker 9.0 for PC Questions & Answers
sorry no idea what you think we can do posting on this repair forum
Computers &... | Answered 1 hour ago
Change the default keyboard
From the Home screen, swipe up on an empty spot to have open up the Apps tray and then Tap Settings and General management and Language and input and Default keyboard.Then select the Samsung Keyboard.
Computers &... | Answered 11 hours ago
Depends on the problem with it.
Straightforward enough to repair whatever the issue.
Computers &... | Answered 19 hours ago
Good to hear that you want to design an E store.Then leave all your concerns apart be cool and go with http://www.makeanysite.com an amazing platform where the users can build their website and at the same time enjoy more offers like Unlimited Hosting,Free Life time Domain,Unlimited Emails.Unlimited Pages and lots.Highly complex websites with Ecommerce,Blogs, Slide-shows,Forums are the unique features of makeanysite.com
Computers &... | Answered 21 hours ago
you can check the link to find https://bit.ly/31rSHrh
Computers &... | Answered Yesterday
If it's Model: 100012590, then it appears there's no adjustment.
Look at its function, then how to remove it if you still want to:
https://www.google.com/search?client=firefox-b-1-d&q=trayapp
100,000
+ 87
_______
100,087
If you're referring to the dongle used with a wireless mouse or keyboard, I believe you have to buy a new setup. The same would apply with a wireless adapter.
The graphics card supplying the signal could be bad, a pin could have been bent over when you plugged in the vga cord (if a vga display).
If a pin is bent, be careful bending it back; it can break off easily. Grab with needle-nose pliers or tweezers, and slowly bend. Don't over-bend.
I would:
  • try checking all connections, especially the power cord to the back of the monitor.
  • try a different monitor as a test to see if the monitor is bad or the graphics card supplying the signal.
  • Once you've narrowed down the cause you'll know what to replace.
Sorry, I don't have any cure for a bad monitor.
There is software what allows for clonning non-copyprotected dvd. It is called CloneDVD. There are ways to remove copy protection but this you have to find on your own, since this forum is not about pirating dvd. For your information even blueray disks can be copied using right software and compatible drives. You need to do your own research. Maybe DVDFaB ? ??????
5505E MEASUREMETER BATTERY CHANGE (3V CR-2032)
REMOVE WHEEL AND SHAFT BY GENTLY PULLING AXLE OUT OF UNIT.
DRILL OUT 7 PLASTIC HEADS WITH 3/16 DRILL BIT. (ABOUT 1\8 DEPTH)
SPLIT TWO SIDES OF CASE AND REMOVE HANDLE.
SLIDE OUT CLEAR PLASTIC CONTROL UNIT. PUSH DOWN ON BUTTONS AS YOU REMOVE SO AS NOT TO DAMAGE THEM.
PUSH DOWN SLIGHTLY TOWARD THE CASE ON LOCK TABS WHILE GENTLY PULLING CASE APART. START ON ONE END AND WORK YOUR WAY TO OTHER END. KEEP GASKET INTACT. OPEN CASE.
THERE IS A "Y" SHAPED RETAINER HOLDING IN THE BATTERY. WITH NEEDLE NOSE PLIERS, CAREFULLY SLIGHTLY SQUEEZE THE BOTTOM OF THE "Y" AND PULL UP GENTLY. YOU CAN NOW REMOVE THE BATTERY AND INSTALL THE NEW ONE. PUSH RETAINER DOWN TO LOCK BACK IN.
MAKE SURE GASKET IS IN PLACE AND PUT CASE BACK TOGETHER, MAKING SURE WHEEL ADAPTER IS IN PROPER PLACE. TURN ON AND TEST CONTROL UNIT AND TURN WHEEL ADAPTER TO MAKE SURE UNIT IS WORKING PROPERLY.
SLIDE CONTROL UNIT BACK IN BEING CAREFUL OF THE BUTTONS. RE-ASSEMBLE HANDLE AND PUT THE TWO SIDES OF THE CASE TOGETHER. I USED THREE PIECES OF ELECTRICAL TAPE TO HOLD CASE TOGETHER. ONE ON THE TOP BETWEEN THE TWO HOLES, ONE ON THE BOTTOM JUST ABOVE THE DISPLAY, AND ONE IN THE MIDDLE.
PUT THE PLASTIC PIECE IN THE HOLE AND LINE UP. MAKE SURE BOTH O-RINGS ARE ON THE AXLE SHAFT. GENTLY INSERT AXLE ALL THE WAY IN WHILE ROTATING IF NECESSARY.
I WAS SO HAPPY I HAD IT ALL BACK TOGETHER AND WORKING, I HADN'T TAKEN ANY PICTURES AND I DIDN'T FEEL LIKE TAKING IT ALL APART AGAIN. MIGHT ADD PICTURES LATER IF NEEDED. I HAD BEEN LOOKING FOR YEARS ON HOW TO CHANGE THE BATTERY, AND I FINALLY MADE UP MY MIND THAT I WAS GOING TO DO IT.
JMS 10-20-2020
For which model u need boot options
Computers &... | Answered 2 days ago
hi Carol.
this is all i could find out.
Click on a link below for further assistance. Macy's Money is a rewards card that you can receive by making qualifying purchases with any form of payment, online and in-store. Use your Macy's Money in addition to coupons & sale prices, even on our best brands - including cosmetics and fragrances!
What is Macy's Money and how do I redeem it? - Macy's Customer ...
https://www.customerservice-macys.com/.../what-is-macys-money-and-how-do-i-redeem...
plus you could go to this link might help you to find out.
How do use my money at Macy Google Search
Computers &... | Answered 3 days ago
Sybase InfoMaker 9.0 for PC Logo
7 questions posted
Top Sybase Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Sybase Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Sybase Computers & Internet
Most Popular Question
need help find download evaluation
  • Computers & Internet
