20 Most Recent Sanyo Xacti VCP-HD2 Camcorder Questions & Answers
I have the HD2. I have to install code pack called CCCP to play my video on my pc. It's come with a Zoom player too. http://www.cccp-project.net/download.php?type=cccp
Sanyo Xacti... | Answered on Oct 17, 2019
Hello, henryrich874! You can try this photo recovery software (also recover music and video files); it can help you recover your lost photos and movies from your Sanyo Camcorder:
Photo Recovery for Windows Users
Photo Recovery for Mac Users
Remember not write any thing to the device until you have got your photos and movies back!
Best wishes!
Sanyo Xacti... | Answered on Oct 28, 2013
take the LCD apart & look up the numbers on the back of it, order the part from were ever you find it form google & put the new one in urself when it arives, this will safe you @ least 100$ on someone else doing the same thing
Sanyo Xacti... | Answered on Feb 11, 2013
There are a few things that could have gone wrong ..The first you may have fried it ..by using a larger voltage one ..and in this case you should see what is wrong with it ..Probably a fuse on the main board if you are lucky ..
Another thing ...the batteries could be damaged from the same cause..and now they can not keep the power and need to be replaced..
Or the plug was damaged cause you forced a wrong charger into it ..and in this case ..if you plug a charged battery ..it should work ..and you will know it is something wrong with the charging route ..and see what need to be changed.,.The plug ..maybe a wire being damaged..The main idea is even if they look the same ..and have the same plug ..the chargers are not the same ...they have differen voltage and amperage..and its not a good idea to improvise ..if it is just the battery ..it will power up with the original charger..if it do not ..I think you should have it seen by a professional ..at least to give a certain diagnostic and see if it is worth repairing or not ..
Sanyo Xacti... | Answered on Aug 15, 2011
Assuming you mean the VPC-HD2, you can download the manual from the manufacturer's web site at
http://us.sanyo.com/dynamic/product/Downloads/VPC-HD2_OM_English-6327393.pdf
Sanyo Xacti... | Answered on Jun 01, 2011
This is your manual.
Sanyo VPC-HD1AEX VPC-HD1
https://dmc.wisc.edu/images/EFLmanuals/sanyo_xacti_vpc-hd1a.pdf
You can download it from above link.
Regards.
Sanyo Xacti... | Answered on Apr 09, 2010
try connecting a 9volt battery with a couple of jumper wires to the correct terminals on the battery for about 30 seconds then put it on charge(positve to positive negative to negative) if the battery is to low the charger won't pick it up and start the charging cycle by connecting the 9volt to it t will put a small charge to it to start the charger
Sanyo Xacti... | Answered on Oct 15, 2009
Make sure you are connecting directly to the computer's USB port, not through a hub. Try disconnecting other USB devices before plugging in the camera. Check the manufacturer's website for updaded drivers: if all else fails, a reinstall of the camera's drivers may be in order.
Sanyo Xacti... | Answered on Feb 14, 2009
Dear FixYa,
Thank you for your email asking whether I had received a solution to the problem I posted yesterday on your company's site.
I have not had any response to the problem I posted and will think about your offer to solve the problem for the fee you mentioned in your message.
I have had trouble finding your email address as the return address you left says 'do not reply', nevertheless I feel you may get this messasge by some means, perhaps someone in your company will pass it on.
Thanks again for your mild interest.
Yours sincerely,
text me with a solution.
+07879023247
Sanyo Xacti... | Answered on Jan 06, 2009
Yes, I get red flashing too occasionally.
turn the power off and on using the button under the screen.
reformat the card either via a computer of if possible via the camera menu item.
Remove and re-insert the card.
purchase a new and faster SD card.
Sanyo Xacti... | Answered on Jan 04, 2009
Hmm...I can't find a software control either. When the flash is down there is a cross through the lightening mark in the upper left portion of the screen, and when I press the flash button and raise the flash the same lightening mark in the upper left has no cross through it. Do you have the same mark? Does the flash button have no effect upon the mark?
Try removing the battery and putting it back in again. This happens to mine. Also make sure that the SD card is fast enough. I.e. a 40x SD or more card or a class 6 SDHC card.
on Xacti HD2 "menu" button doesn't respond in Recording mode... any suggestions?
Perhaps your camera only comes with a trial or limited edition of the software. Try proceeding without the activation code and/or read through the camera's documentation very carefully.
Sanyo Xacti... | Answered on Mar 01, 2008
Well, There is an extra cord that connects to the computer and the camera, I don't know the exact name of this But If you have this and are needing help with that, a pop up from your computer should come up saying "Input device" and you should be able to do it there easily.
Sanyo Xacti... | Answered on Nov 29, 2007
What model Sanyo camera? What type and size memory card? Just what problem are you encountering? Is there an error message?
Sanyo Xacti... | Answered on Oct 15, 2013
Just let it dry in room temperature for a day. Then try switching on. If it still doesn't work take it to a store.
Sanyo Xacti... | Answered on Oct 30, 2012
Sanyo Xacti VCP-HD2 Camcorder Logo
Popular Tags
26 questions posted
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Nicola Conroy
abdul rauf
abdul rauf
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Xacti Sanyo
  • Xacti Sanyo
Most Popular Question
recover deleted photos movies
  • Video Cameras
