20 Most Recent Amana ABD2233BT Questions & Answers
manual
ABD2233BT Manual
Amana RefrigeratorsUploaded on Oct 24, 2013
Amana SXD2252 side by side ice maker stopped, now leak on floor
ck here... https://www.appliancepartspros.com/repair-help/amana-refrigerator-sxd22s2w-repair/sxd22s2w-leaking.html But before throwing parts at it give their tech 877# a hollar.. Best to you
9/4/2023 5:56:53 PM • Amana... • Answered on Sep 04, 2023
Amana ARB1917CSR 18.5 Cu. Ft. Plus Refrigerator. What is the HP of my compressor, which Supco relay and run capacitor?
What tends to happen is that service techs have certain common generic parts in their van, and rather than ordering a part to fit and have a return visit, they fit what they have. Parts seem to be readily available. The compressor is listed but no HP Specs. The bottom show another model and that R134A (1/4HP) is different to R134 (1/5 HP). https://www.google.com/search?q=amana+arb1917csr+parts+diagram https://www.google.com/search?q=Tecumseh+TP122AR003B8 ..
7/27/2023 6:43:23 PM • Amana... • Answered on Jul 27, 2023
3answers
Need to find water filter on my amana model
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
6/20/2023 3:26:22 PM • Amana... • Answered on Jun 20, 2023
Possible cause of Amana refrigerator making a constant clicking/noise?
Sharla, It could possibly be the ice maker rod that tells the ice maker whether it's full or not. If it's in the down position it wants to make ice and it'll make a clicking noise. Lift the rod up if it's down. Hopefully this helps!? Best to you.
4/21/2023 7:28:31 PM • Amana... • Answered on Apr 21, 2023
3answers
What year is my Amana refrigerator, Model # ASD2522WRB06?
I'd like to know how you determine the age based on the info inside my Amana. I double checked the numbers. Model AFI2538AEB4 Serial KY2886165
3/4/2023 11:22:10 PM • Amana... • Answered on Mar 04, 2023
Afd2535des not cooling in any department, when I opened the doors, the lights work and the led temp control lights up. I hear a fan start and 5 seconds later the fan stops n leds shut off.
  1. Check the thermostat: Make sure the thermostat is set to a temperature that is low enough to cool the refrigerator. If the thermostat is not working properly, it may need to be replaced.
  2. Check the condenser coils: The condenser coils on the back of the refrigerator should be clean and free of dust and debris. If the coils are dirty, the refrigerator will not be able to cool properly. Use a vacuum cleaner or a brush to clean the coils.
  3. Check the fan motor: If the fan motor is not running, the refrigerator will not be able to cool properly. Check if the fan motor is receiving power and if it's spinning freely. If the fan motor is faulty, it will need to be replaced.
  4. Check the start relay: The start relay helps the compressor start up. If the start relay is faulty, the compressor may not start and the refrigerator will not be able to cool properly. If the start relay is faulty, it will need to be replaced.
  5. Check the compressor: If the compressor is not working, the refrigerator will not be able to cool properly. Check if the compressor is receiving power and if it's running. If the compressor is faulty, it will need to be replaced.
2/16/2023 2:42:10 AM • Amana... • Answered on Feb 16, 2023
No power to Amana ice and water dispenser. Rest of refer runs fine.
It's possible that the issue could be with a micro switch located on the ice maker cabinet that is activated when the prong on the back of the ice/auger tray is inserted. It's also possible that there could be another issue with the dispenser, such as a problem with the wiring or a malfunctioning component. I would recommend checking the wiring and testing any other micro switches or components that are related to the dispenser to see if they are functioning properly. If you are unsure how to do this, I would recommend consulting the user manual or contacting a qualified technician for further assistance.
1/14/2023 10:27:43 AM • Amana... • Answered on Jan 14, 2023
Where is the defrost timer located in Amanda Model SXD2252W
check to see if defrost fan working
10/19/2022 2:58:33 AM • Amana... • Answered on Oct 19, 2022
How do you remove the light cover from amana refrigerator model arb2107?
I have an Amana AS12575GRB01, the cover to the light bulb on the fridge side is mounted on the top inside back right corner. Having problems removing it
9/8/2022 1:07:18 PM • Amana... • Answered on Sep 08, 2022
I have an Amana Fridge (model ABD2533DEW) that makes a buzzing noise for about 10-12 seconds and then clicks off.
There are several videos on line about buzzzing fridges. This is one https://www.youtube.com/watch?v=O2TVZazGLJ0
6/29/2022 2:41:17 PM • Amana... • Answered on Jun 29, 2022
2answers
Refrigerator not cold and have
4/9/2022 3:40:32 AM • Amana... • Answered on Apr 09, 2022
3answers
How do I remove the factory installed Amana household refrigerator for repair?
Hello, Stephen -I am not finding relevant information for you. I do not own an Alpenlite Fifth Wheel RV myself.I suspect you will receive relevant instructions from another owner. For that, if you have not already posted your question on an online RV discussion forum, I suggest you do so. These are links to some forums. Registration is required for each, but they are all free:iRV2:http://www.irv2.com/forums/f104/alpenlite-5ers-125073.htmlRV.net:http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/22871819.cfmRVNetwork:http://www.rvnetwork.com/Technical Tips & Tricks is probably the best category for your refrigerator question.RVTalk.com (RVUSA):http://www.rvtalk.com/Both the RV Tips & Tricks and the Towables category would be the best for you to post your question.Best wishes
1/13/2022 5:29:47 PM • Amana... • Answered on Jan 13, 2022
I need a wiring diagram for hooking up the wires from the dispenser control board on facia of a Amana ARS2664bBW refrigerator
Contact Amana directly to request the wiring diagram.
8/20/2021 8:28:56 AM • Amana... • Answered on Aug 20, 2021
I have an Amana refrigerator ABB2222FEW, freezer on the bottom. There is a smell coming from the fans flowing into the fridge. Food has been removed, fridge cleaned, still smells. Can you help?
FOUL TASTE OR SMELL IN ICE OR WATER FROM FRIDGE Check ice and water filter: If equipped, the Ice and Water filter in your refrigerator is responsible for removing any debris or contaminants from your water that may still remain after local water treatment. Most filters contain and are made up of carbon and fabric filter. Over time, the filter may become restricted and reduce the water flow to the ice maker, causing a symptom of little or no ice. Most manufacturers recommend replacing the filter every 6 months but local water conditions may require that you replace more frequently. Lastly a clogged drain line can cause a foul smell and get into the ice and water as we,,. http://www.appliancerepair.net/refrigerator-repair-1.html
8/14/2021 11:31:22 AM • Amana... • Answered on Aug 14, 2021
My Amana 19cu ft refrigerator, freezer on the bottom. Refrigerator stopped working, freezer is still working, MODEL DRB1901CW. S/N109533070CE
There are plenty of reasons this could happen like the following: PROBLEM POSSIBLE CAUSE Loud operating sound level • See "Sound Information" section for explanation of normal operating sounds Freezer too warm. Compressor not operating • Freezer temperature set too warm • Defective compressor • Defective overload or relay Refrigerator too cold • Refrigerator temperature set too cold • Chefs Pantry control set too cold or misaligned allowing freezer air to escape into refrigerator section • Freezer temperature set too cold • Restricted condenser air • Refrigerant shortage or restriction • Refrigerant overcharge Freezer too warm. Compressor cuts off on overload • Heavy usage • High ambient • Restricted condenser air • Defective condenser fan motor • Loose or missing condenser fan blade • Improper voltage • Defective relay or overload • Compressor motor winding • Non-condensibles in system • Refrigerant overcharge Freezer too warm. Compressor operating • Freezer temperature set too warm • Restricted condenser air • Defective condenser fan motor • Opened door • Heavy usage • Defective freezer fan motor • Opened defrost thermostat • Opened defrost heater • Loose or missing freezer or condenser fan blade • Heavily frosted evaporator • Refrigerant shortage or restriction • Inefficient compressor Refrigerator too warm • Refrigerator temperature set too warm • Freezer temperature set too warm • Return air or air supply duct blocked • Chefs Pantry control set too warm or air supply tube blocked • Heavy usage • High ambient Problem Possible Cause Freezer too cold • Freezer temperature set too cold Long off cyde • Low ambient • Freezer temperature set too warm Short off cycle • Heavy usage • High ambient • Freezer temperature set too cold • Light constantly on • Poor door gasket seal Long or continuous run cyde • Heavy usage • High ambient • Inadequate condenser air flow • Freezer temperature set too cold • Loss or restricted refrigerant Short run cycle • Light usage • Low ambient • Freezer temperature set too warm Exterior cabinet condensation • High humidity. Design accepts beads of water on cabinet exterior after 4 hours with 0° to 2°F (-18° to -17°C) freezer food temperature and 38° to 40°F (3° to 4°C) refrigerator food temperature in 84% R.H. conditions. See "Typical Sweat Pattern" section under above conditions. • Freezer temperature set too cold • Poor door gasket seal • Insulation void
2/24/2021 9:30:34 AM • Amana... • Answered on Feb 24, 2021
Amana AF12538AES Ice maker replacement
Adverts for repair and replacement parts, plus videos here https://www.google.com/search?q=Amana+AF12538AES+Ice+maker+replacement ..
12/16/2020 9:38:04 PM • Amana... • Answered on Dec 16, 2020
Refrigerators Logo
0 questions posted
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
possible cause amana refrigerator making
  • Refrigerators
