20 Most Recent
Dell (Fan Only) M/N AFC0912DE, DC12V, 2.50A, D/N P2780 P2780 Questions & Answers
I have a dell 8400
the bios monitors the processor Temperature and increases fan speed if its gets hot. I recommend, get a can of air and blow out the processor's heat sink, as it could be getting dirty and preventing air flow for cooling. otherwise you have some software that running the CPU at a high rate for a long period of time. Use control +alt +Del then switch to task manager, if you click on the CPU heading it will order the tasks by CPU usage, look for the ones that are at the top of the list. note:system idle process should always be way up there 95-100% CPU, this on is OK. all else look into. you can "end task" one the offensive one and look up more details on the web about that application.
I look forward to your comments.
Thanks
CPU Fan sounds like a jet and computer won't start
It sounds more like the hard drive, the fan has nothing to do with your computer booting up. If the hard drive is starting to go bad it will not boot up, that's what it sounds like your computer is doing. I recommend checking out the hard drive and replacing it.
Cooling fan
thermaltake fans arfe very good look online for them
Fan Races Computer Won't Start
The fan is drawing too much current from the motherboard causing the power supply to go into protection mode. Try replacing the fan with a new one and see this this does not fix the start up problem. You should check out your power supply and see if it really delivers enough power to power all the devices in your computer. The power supply could have weaken due to overheating and aging. Try checking the voltages with a software device like speedfan or hardware monitor and see if the voltages are intermittant or out of specs. These programs can be downloaded free from their websites. Just google them to find the websites. If they are you should replace the power supply. Hope this helps you with your problem.
Fan
No reply
Can't help without details, sorry
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
Dell Precision M4600 will not go past POST, Stops at Preparing to enter setup
If your Dell Precision M4600 is getting stuck at the "Preparing to enter setup" stage during POST, you might want to try a few troubleshooting steps.
1. **Power Cycle:** Disconnect the laptop from the power source, remove the battery (if possible), and hold down the power button for about 15 seconds. Then, reconnect the battery and power source and try booting again.
2. **Reset BIOS:** You could try resetting the BIOS settings to their default values. To do this, look for a small button battery on the motherboard. Disconnect the laptop from power and remove the battery. Press and hold the power button for a few seconds to discharge any remaining power. Then, locate the battery, remove it for a minute or so, and put it back. This will reset the BIOS settings to default.
3. **Update BIOS:** If the issue persists, you might need to update the BIOS. Check the Dell support website for your laptop model and download the latest BIOS update. Follow the instructions to update the BIOS.
4. **Check Hardware:** If the issue is not resolved, it might be related to a hardware problem. Try removing and reseating components like RAM, hard drive, and any expansion cards.
5. **External Devices:** Disconnect all external devices (USB drives, external hard drives, printers, etc.) and try booting again. Sometimes, a faulty external device can cause boot issues.
6. **Diagnostic Lights:** Dell laptops often have diagnostic LED lights that provide information about hardware issues. Check the user manual for your laptop model to interpret these lights.
If none of these steps resolve the issue, it might be worth seeking professional assistance or contacting Dell support for further guidance.
