20 Most Recent LG 60PA5500 Questions & Answers
Hi..Tom, you have a bad main BPR assembly(where the cpu lives) part #EBU1590708 approx $150-$175. Check with Shop Jimmy.com. You will probably require the product code and serial number of your unit.
LG 60PA5500 | Answered on Mar 19, 2015
If this unit has a network connection then it is able to stream netflix, youtube etc.
LG 60PA5500 | Answered on Mar 15, 2014
Try doing an "AC reboot" by unplugging the TV, waiting 30 seconds, then plugging it back in. Sometimes the microprocessor get s glitched from blips in the power. If that does not cure it, there are issues on the mother board that need repair.
LG 60PA5500 | Answered on Dec 04, 2013
Depending on the model maybe. Tv's like all electronic items use multiple circuits that are interconnected. So if you have a problem like you described it can be any interconnected board. I experienced problems like you described many times. Use your eyes and nose. Turn off the power, remove all boards and visually inspect. While boards are out sniff each board. Look on both sides of each board. If nothing is found I would start with the power supply and replace it. You can check the output voltage where the power supply connects the the main board. It is harder to check the main board function because the signals pulsing thru the main board require specialized equipment.
LG Televison &... | Answered on Nov 27, 2020
The power supply could be failing.
LG Televison &... | Answered on Nov 12, 2020
1. Open internal fuse
2. Power supply failure
LG Televison &... | Answered on Nov 11, 2020
That is the right amount of voltage the issue is when one or more of the individual LED lights fail, the current changes and the power supply senses it and shuts down.
LG Televison &... | Answered on Nov 05, 2020
You could use headphone plug with adapter for audio out. For more hdmi ports you can buy hdmi switch. Svc port is for service.
LG Televison &... | Answered on Oct 29, 2020
Use code search on your Audiosonic URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
LG 60PA5500 Logo
10 questions posted
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
View Most Popular
  • LG Televison & Video
Most Popular Question
lg 60pa5500 tv 5 years old just started
  • Televison & Video
