20 Most Recent
Sanyo Dp50741 Questions & Answers
I have a sanyo dp50741 the wife was watching it
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Led blinking red on a sanyo dp50842
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy.
For more information, check the link http://electronicshelponline.blogspot.com/
Sound isn't working on my tv
Check its speaker first. Check whether the sound is muted. If all are OK, check and replace its audio output card.
If you wish to get more details, check this site linked
below. Pull up older posts there. Check
the site with patience, as it has over 2350 posts now. All are related to electronic equipment
repair help. If you search the site in
Timeslide option, which can be selected from the drop down list at the top left
of the display window, it will be easy to locate the related post. You can also do a search by type in the
brand name to your device into its search box at the top right of display
window.http://electronicshelponline.blogspot.com/
Power wont stay on
There should be some fault with its main digital board. If you wish to get more details, check
this site.
Pull up older posts there. Check the site with patience, as it has over
2250 posts now. All are related to
electronic equipment repair help.
Search the site by 'Timeslide' option.
It will make search easy. Or,
type in the brand name to your device into its search box, and press "Enter"
MY SANYO DP50741 POWER BOARD?
i would check to see if the stand by supplies are on the power board and then check to see if the on supply comes up briefly when power is pressed it could be the power board or main board testing the supplies will narrow down which board you need.
Lost 50 in.tv audio
Check audio connections if it is an external source and also check other input sources like a DVD player to see if the audio comes from that. If you never get any audio it could be a power supply issue or a amplifier that has broken solder joints on the board. I have had to repair many wave soldered boards over the last 40 years due to little solder on the component leads and then some parts that handle power or get hot develop what is called a thermal break in the soldering that connects the component lead. If it is not a bad setting or cable into the display device then you might need to consult a Technician.
Sanyo TV power cord removal Model DP19649
It unplugs.https://www.amazon.com/POWER-CABLE-SANYO-DP19241-DP26670/dp/B019XGHRO8orhttps://directtvparts.com/sanyo-tv-dp19649-power-supply-1av4u20c38500-dac-12m069-2995321500/
