20 Most Recent Philips Phillips - 40" Class - Led - 1080p - 120hz - Smart - Hdtv Questions & Answers
The easiest way is to directly connect through ethernet, then it won't have to find a password. If you are going through Wi-Fi you'll need to go into the settings in your TV and setup through there. Have your pw ready for your wifi.
Philips Phillips... | Answered on Aug 29, 2016
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Philips Phillips... | Answered on Jun 02, 2016
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Philips Phillips... | Answered on May 09, 2015
I know inside an LG tv the "Y" and "X" sustain boards are situated at each side of the screen, but other models may differ
Philips Phillips... | Answered on Sep 10, 2014
No repair can be done for a broken screen. Replacement only can be done. But it will cost 2/3rd of the total cost of the TV. If you think it is OK, replace it. Otherwise buy a new TV. It will be the best.
Philips Phillips... | Answered on Apr 16, 2013
Check and replace its T'Con board. Check all connecting wires [flat cables] that goes to panel out of T'Con board for any loose contact. Re-seat them once, and check.
Philips Phillips... | Answered on Jan 30, 2013
There is no raster to your TV I assumes. If the LED drive inverter board has damaged, there will be no back light, and so no picture. If sound is OK, suspect the inverter board. Check this for more details.
Philips Phillips... | Answered on Jan 08, 2013
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Philips... | Answered on Dec 21, 2020
The Philips CSS2123B/F7 uses a remote control to power on the sound bar. See the documentation here: https://www.usa.philips.com/c-p/CSS2123B_F7/soundbar-home-cinema-speakers/support . You can find a replacement remote here: https://www.amazon.com/Replacement-996510054954-996510050576-996510063326-CSS2123B/dp/B06XK1TW4C or here: https://encompass.com/model/PNFCSS2123'F7 . Otherwise, find a universal remote control that is compatible with the Philips sound bar. You may need to try multiple codes to get it to work.
I hope this helps. If the IR receiver is not working on this sound bar, then I'm not sure it's worth repairing the unit.
Philips... | Answered on Dec 19, 2020
Sorry but fixya.com doesn't sell things and are unable to quote.
Quite often the capacitor of a motor is housed in a small box attached to the motor and the design is such that only a like-for-like replacement will fit and maintain the "enclosed" design of the motor and faced with this problem, many will resort to buying a replacement as a spare part of the machine from the original supplier or manufacturer.
Those that choose this route usually pay four or more times the cost of a replacement from a capacitor supplier. Phillips would usually be happy to provide you with details of their local stockists.
If a capacitor with different dimension will fit the housing then almost any motor specialist or capacitor supplier will be able to provide a replacement. Link below to such a company...
https://www.specap.com/?gclid=Cj0KCQiAw_H-BRD-ARIsALQE_2OgIvdqN-v_UPllr17WeFTBB3FURp4mwBIlZpNJBH5NEUv97a5joCoaAmuvEALw_wcB
Remote Control Codes For Philips TVs
  • Philips TV Codes. 1004. 1007. 1011. 1017. 1018. 1047. 1053. 1056. 1057. 1059.
  • Philips DVD Codes. 2032. 2033. 2045. 2051. 2091. 2109. 2156. 2157. 2158. 2159.
  • Philips Audio Codes. 4006. 4027. 4039. 2304.
  • Philips VCR Codes. 3016. 3036. 3047. 3061. 3071. 3135. 3160. 3173. 3208. 3216.
  • Philips Receiver Tuner Codes. 5000. 5112. 5138. 5143. 5145. 5154.
Remote Control Codes For Philips TVs ' Codes For Universal ...
Philips... | Answered on Dec 17, 2020
Use code search on your Philips URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
Philips... | Answered on Dec 08, 2020
Philips Phillips - 40" Class - Led - 1080p - 120hz - Smart - Hdtv Logo
14 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
trying setup phillips tv bt vision box
  • Televison & Video
