20 Most Recent
Antec (NOTEBOOKCOOL) Laptop Cooler Questions & Answers
My Lap top cooler stopped
The fan may have failed, you will have to replace the fan or cooler. Check to see if there are any loose wires.
5/2/2011 8:35:13 PM •
Antec...
Answered
on May 02, 2011
Tried to sign up for googlemail keep asking for
that's called captcha recognition. You should type in the confirmation word(s) that look squiggly or fuzzy. They do this so that they know you are an actual person requesting the email account and not a Spambot.
3/21/2011 10:15:32 PM •
Antec...
Answered
on Mar 21, 2011
HOW TO FIX ANTEC AR-352
Unfortunately, there are not many parts available off the shelf to repair these. It would be simpler to get a power supply with a greater wattage rating than the one you have now.
Cannot get to the internet
What kind of Internet connection do you have
DSL, Fiber, Cable? do you have a modem? Do you have a router? Are you connected via Ethernet cable or wireless?
In order to start any diagnosis I need the answers to these and maby some other questions
Weird start-up problem
Recheck all your board connections. I missed a connector by one pin and got nothing as you have. Once I realized my mistake and re connected the plug on to the board correctly everything worked.
MAKE +IT STOP
so check the cable....
some computers beeps because something is plugged not correctly....
I guess it's memory ....
try to remove and plug in back memory cards
Two wires need a home
If everything is working, those wires may be extra for expansion needs. There are several wires not connected to anything inside a PC
