20 Most Recent
Stanton C-504 Dual Cd Player CD Player Questions & Answers
It plays some cd
Well this happens because your CD player is region lock, and you need to unlock your player so that it plays all CD's. check your user manual for the region unlock code if the region code is not there then ask to your dealer for that code.
Good Luck!!
Thanks
Cd skiping
If the disc is clean, that could be some dirt on the laser head lenses.
My Stanton STR8-60 is not tuned correctly. I need help trying to get it to hold the right rpm for the platter.
You know it isn't for playing records. It is made for DJ Scratching from the 1980s.
Str8-60, any facts of info?
Vinyl Engine
https://www.vinylengine.com > viewtopic
Feb 18, 2012 - The s
tr8-60 is the bottom of the line dl deck from stanton, and has straight tonearm. it is
designed for dj use and is not really suitable for ...
AT150MLX on Stanton STR8-60? - Vinyl Engine
May 25, 2016
Ground wire repair on Stanton STR8-60 - Vinyl Engine
May 5, 2021
Stanton STR8-60 Replacement Power Cable - Vinyl Engine
1 post
Apr 18, 2021
Picking a cartridge with a turntable with no anti-skating
Mar 31, 2015
More results from www.vinylengine.com
stanton str8-60 : r/turntables
Reddit · r/turntables
2 comments · 9 months ago
The
STR8 turntables have a totally straight tonearm designed for DJ "scratching". If you just want to listen to records, they're not good ...
$50 Stanton STR8-60 got picked up today; all it needed was a ...
May 20, 2021
Stanton STR8 any good? : r/vinyl - Reddit
Oct 29, 2015
Stanton turntable model str8-50 vs. AT LP-60? - Reddit
Nov 13, 2023
Two Stanton T.60's and a M.202 mixer for $150? : r/DJs - Reddit
Jan 11, 2019
More results from www.reddit.com
How do i replace burnt fuses on stanton t62 m2 turntables
If they are the glass type fuses then they might still have the wattage on the metal ends.
However that might be the least of your problems. Fuses blow like that due to an overload. So you should look around for a shorted device such as a power transistor or anything having an heat sink on it.
