20 Most Recent Amana ASD2622HR Side by Side Refrigerator Questions & Answers
RE: ASD2622HRW (7yo) The freezer
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
7/30/2011 3:38:44 PM • Amana ASD2622HR... • Answered on Jul 30, 2011
I WILL NEVER BUY ANOTHER AMANA PRODUCT AND I AM
Take a look at all of the people that post about problems with their appliances. It is not just Amana, but just about every make modle you could imagine.
1/10/2011 6:22:00 PM • Amana ASD2622HR... • Answered on Jan 10, 2011
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
11/18/2010 7:33:44 PM • Amana ASD2622HR... • Answered on Nov 18, 2010
0answers
Shut water off did not shut off ice maker- now ice
Good day,
Assuming the water has been turned back on for a while, and your sure it's getting to the valve on the rear, follow this guide.
It should cover your problem. The freezer must be cold enough. 10 degrees or colder.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
9/27/2010 6:45:59 PM • Amana ASD2622HR... • Answered on Sep 27, 2010
ASD2622HRW Freezer side cold, refrig
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
7/31/2010 11:15:12 PM • Amana ASD2622HR... • Answered on Jul 31, 2010
No longer cold, and no longer freezing ice.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
6/27/2010 4:19:28 AM • Amana ASD2622HR... • Answered on Jun 27, 2010
Water is dripping into ice recepticle and causing
sounds like u have a bad ice maker or a bad water solenoid in the back of fridge just not shutting off all the way and letting water continiously drip into ice trap
2/24/2010 1:25:27 AM • Amana ASD2622HR... • Answered on Feb 24, 2010
Amana model # ASD2622HRW will not defrost
If this keeps happening then it is most likely that the controller board is faulty and needs replacing.
9/11/2009 4:27:40 PM • Amana ASD2622HR... • Answered on Sep 11, 2009
Refrigerator not cooling.
compressor has failed. not a diy job
5/17/2008 4:38:20 PM • Amana ASD2622HR... • Answered on May 17, 2008
Ice maker not working on Amana Side by Side refrigerator
On most Amana cabinets the water supply for the water and ice are from two solenoid valves. The water coming in goes to a double water solenoid valve splitting the incoming water so the fact there is water coming through as chilled water is not verifying that there is water supply for the ice maker. If technically minded you could locate this valve (normally at the back rhs ; compressor section) and try switching the supplies to check the solenoid valve. If you have water coming through then it may well be the icemaker module not asking for the water supply. As the simplest first step I would try defrosting the whole machine overnight and see if there is an improvement. I do know that checking the module is time expensive and would really need to be done by an engineer or alternatively replace this item. Hope this is of some help.
8/28/2007 10:49:13 PM • Amana ASD2622HR... • Answered on Aug 28, 2007
I need a wiring diagram for hooking up the wires from the dispenser control board on facia of a Amana ARS2664bBW refrigerator
Contact Amana directly to request the wiring diagram.
8/20/2021 8:28:56 AM • Amana... • Answered on Aug 20, 2021
I have an Amana refrigerator ABB2222FEW, freezer on the bottom. There is a smell coming from the fans flowing into the fridge. Food has been removed, fridge cleaned, still smells. Can you help?
FOUL TASTE OR SMELL IN ICE OR WATER FROM FRIDGE Check ice and water filter: If equipped, the Ice and Water filter in your refrigerator is responsible for removing any debris or contaminants from your water that may still remain after local water treatment. Most filters contain and are made up of carbon and fabric filter. Over time, the filter may become restricted and reduce the water flow to the ice maker, causing a symptom of little or no ice. Most manufacturers recommend replacing the filter every 6 months but local water conditions may require that you replace more frequently. Lastly a clogged drain line can cause a foul smell and get into the ice and water as we,,. http://www.appliancerepair.net/refrigerator-repair-1.html
8/14/2021 11:31:22 AM • Amana... • Answered on Aug 14, 2021
My Amana 19cu ft refrigerator, freezer on the bottom. Refrigerator stopped working, freezer is still working, MODEL DRB1901CW. S/N109533070CE
There are plenty of reasons this could happen like the following: PROBLEM POSSIBLE CAUSE Loud operating sound level • See "Sound Information" section for explanation of normal operating sounds Freezer too warm. Compressor not operating • Freezer temperature set too warm • Defective compressor • Defective overload or relay Refrigerator too cold • Refrigerator temperature set too cold • Chefs Pantry control set too cold or misaligned allowing freezer air to escape into refrigerator section • Freezer temperature set too cold • Restricted condenser air • Refrigerant shortage or restriction • Refrigerant overcharge Freezer too warm. Compressor cuts off on overload • Heavy usage • High ambient • Restricted condenser air • Defective condenser fan motor • Loose or missing condenser fan blade • Improper voltage • Defective relay or overload • Compressor motor winding • Non-condensibles in system • Refrigerant overcharge Freezer too warm. Compressor operating • Freezer temperature set too warm • Restricted condenser air • Defective condenser fan motor • Opened door • Heavy usage • Defective freezer fan motor • Opened defrost thermostat • Opened defrost heater • Loose or missing freezer or condenser fan blade • Heavily frosted evaporator • Refrigerant shortage or restriction • Inefficient compressor Refrigerator too warm • Refrigerator temperature set too warm • Freezer temperature set too warm • Return air or air supply duct blocked • Chefs Pantry control set too warm or air supply tube blocked • Heavy usage • High ambient Problem Possible Cause Freezer too cold • Freezer temperature set too cold Long off cyde • Low ambient • Freezer temperature set too warm Short off cycle • Heavy usage • High ambient • Freezer temperature set too cold • Light constantly on • Poor door gasket seal Long or continuous run cyde • Heavy usage • High ambient • Inadequate condenser air flow • Freezer temperature set too cold • Loss or restricted refrigerant Short run cycle • Light usage • Low ambient • Freezer temperature set too warm Exterior cabinet condensation • High humidity. Design accepts beads of water on cabinet exterior after 4 hours with 0° to 2°F (-18° to -17°C) freezer food temperature and 38° to 40°F (3° to 4°C) refrigerator food temperature in 84% R.H. conditions. See "Typical Sweat Pattern" section under above conditions. • Freezer temperature set too cold • Poor door gasket seal • Insulation void
2/24/2021 9:30:34 AM • Amana... • Answered on Feb 24, 2021
Amana ASD2622HR Side by Side Refrigerator Logo
Popular Tags
24 questions posted
Top Amana Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
re asd2622hrw 7yo freezer
  • Refrigerators
