20 Most Recent
Amana ABB2227DE Bottom Freezer Refrigerator Questions & Answers
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Noisy Amana ABB2227DEB
The motor is an "auto damper" that opens/closes to let cold air from the freezer comp. into the refer comp. depending on the temp. There is nothing you can do for maintenance, the little motor runs the damper when needed automatically. Some motors are quiet, some are noisy (grind grind grind) as the open and close. Sort of the nature of the beast, if you're lucky you get one that stays quiet.
I have an amana bottom
check the regulator or thermostat for the fridge and set it well.
if it is well set then your compressor is losing compression.
There is a humming sound and then click (relay
Yes it could be, I would check the start capacitor with a Volt meter. Or if you can take it off and have a service center check it for you. Unplug the refrigerator first before you do that. Also the compressor could be going out makeing it harder to start. And if that is the case you could ask the service center if they have a hard start kit for your unit if the start capacitor is OK. Hope this helps.
Freezer has light frost in
Sounds like it is not defrosting . Either the defrost timer, heater or thermostat. Leave the bottom door open for 24 hours and will probably work again for about a week till repaired.
Not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
