20 Most Recent APC BE500R Back-UPS ES 500 (BPAPWBE500R) UPS System Questions & Answers
NO POWER OUTPUT
you will need the copy of point of sale. i/e the cash register sales ticket then contact the manufacture, and request the unit to be returned, if that unit is new out of the box, well you will have 100% warranty. ups is a battery backup unit, so contact the manufacture, direct. lhsjr
9/23/2017 2:49:35 AM • APC BE500R... • Answered on Sep 23, 2017
Low voltage output 170 volts
Check your voltage meter, so it measures correctly, probably generate your UPS is not pure sine wave, but a modified sine, then the simple measuring devices to display the wrong value.
1/26/2015 7:31:22 AM • APC BE500R... • Answered on Jan 26, 2015
My APC 500 ES ups has continuous beep when powered battery or AC mode what seems to be the problem
Hi Make sure the batteries are good, if not will have to replace with new
7/23/2014 7:29:33 AM • APC BE500R... • Answered on Jul 23, 2014
Apc us[p es 500 timer always reset
sounds like the battery is low or has been disconnected.
3/18/2014 11:43:48 PM • APC BE500R... • Answered on Mar 18, 2014
Looking for BE500R-PH Service Manual
no service manual
11/15/2013 2:30:54 PM • APC BE500R... • Answered on Nov 15, 2013
0answers
0answers
UPS BE500R-PH microcontroller pic16f716
No, the PIC16F716 microcontroller does not need to be programmed before using it in a UPS. However, it is recommended that you program the microcontroller to optimize its performance for your specific UPS. There is an available schematic diagram for the APC UPS BE500R-PH. This diagram can be found in the "APC UPS BE500R-PH User Manual". Check it here: Back-UPS ES BE500R User guide ' Schneider Electric (apc.com) The most efficient way to use a UPS for a home computer is to connect the UPS to the computer's power supply unit (PSU). This will ensure that the UPS provides power to the computer in the event of a power outage.
11/19/2022 4:29:33 PM • APC Computers &... • Answered on Nov 19, 2022
2answers
I need to know where the serial number and model # is located on my APC mini chopper
you to www.apc.com, choose the country you are in, go to product and services, choose the model you have than check what ever you need for the product you have chosen, good luck
8/11/2022 7:22:25 PM • APC Computers &... • Answered on Aug 11, 2022
2answers
APC BK650EI 650 VA 400 Watts (1) IEC 320 C13 (Surge Protection) (3) IEC 320 C13 (Battery Backup) Outlets Back-UPS CS 650 USB/Serial. It blinks random orange LED.
I say yes he manual shows ,setting sensitivity here. the sound like charger fail. Inside. inverter works, did you let it charge overnight first. and disable the beeper if annoying. is AC line voltage low? that too can beep. is this USA model 120vac or outside USA> also if the UPS is for another country that will be bad. 650EI , is not the E means European version"??? why skip country. >? and matters huge that. EI is 230vac version, and will be wrong used in 240vac countries and worse. yellow led only blink is low line AC as the manual tells my guess you bought the wrong UPS?> v2 docs but not told version page 2. https://download.schneider-electric.com/files?p_Doc_Ref=SPD_AHUG_990-9237_EN&p_enDocType=Quick+start+guide&p_File_Name=BU+UM+990-9237B+MN01+EN.pdf
6/20/2022 2:52:04 AM • APC Computers &... • Answered on Jun 20, 2022
Hello, I am looking for a schematic diagram for APC 650 BK650 MC. Does any one have it? Thank you.
none officiallysome rare versions leak out, try googling for leaks there is no other way to find leaks, (confidential docs)
5/29/2022 11:13:13 PM • APC Computers &... • Answered on May 29, 2022
My power supply APC UPS-ES 700 won't power on ,at all .
APC.com have many here. there are fuses inside that blow too. not just the rear breaker. fails with NO Loads cables connected at all? 1: batteries shorted or dead. short overload it . there is a battery fuse, easy or hard to find ,easy on my loved smt750C. the true model of you UPS is not front stamps but the rear label tells the truth. 2: turn it on with not batteries yet, some turn on with error light or on mine LCD hard text errors,. no bats. 3: that is about it besides bad PCB. ES-700 those pan-cake UPS. sure. batteries do fail for sure out of the blue. (plates inside can short) out of the blue. or one cell goes dry and open and dead. the battery fresh pulled will read 13.0vdc. (good UPS) not 10 not 1, not 0 13. or 12.8v min. rested 5 hours post charged. the brain inside (firmware) is not very smart. it see's any errors it does not like and turns off fast. blink of eye fast . it can. shorts , or battery seen shorted. or blows fuse, deep inside on PCB up to 400volts inside do not touch that with hands, lethal are you on 240vac? we are 120v here.
2/10/2022 12:31:15 PM • APC Computers &... • Answered on Feb 10, 2022
Why won't the new battery allow the xs go on line
let it charge overnight, (new real or new from ebay not new) never assume it is charged new. make sure rear AC circuit breaker on it is not tripped makes sure battery fuse not blown make sure battery lugs not rusty. learn how to bench charge any AGM battery like this at 3amps max, ? (AND ATV CHARGERS IS WOW HERE) 2004 UPS, many were recalled for not having fuse. on the battery feed. and cause smoke. why use 15-04 -11 year old UPS>? MOST THAT OLD HAVE BIG PROBLEMS.
2/6/2022 12:26:30 PM • APC Computers &... • Answered on Feb 06, 2022
OWNERS MANUAL FOR BR1500LCD
apc.com (step 1 tell them your country first, seems you did not.) most easy question on earth . and answered. in usa most APC were banned in jan 2022, a horror here, most discontinued are still supported with manual and software. not deleted. for even 10 or more years.(found it) i can not decode your model (i guess BR is the code) on the rear or side off UPS is a white sticker or service tag for sure and you did that I see. and on such tag is the real model number even encoded for country . and your unstated countries voltage line input. APC BACK-UPS RS BR1500LCD 1500VA/865W UPS System(2006 made) are you in barbados posted to N.Amercias'/ if yes learn to only go to APC site for your country of find nothing you will..... seems not sold in many countries but is old. https://download.schneider-electric.com/files?p_File_Name=ASTE-6Z7VAU_R0_EN.pdf&p_Doc_Ref=SPD_ASTE-6Z7VAU_EN&p_enDocType=Quick+start+guide
2/5/2022 6:55:23 PM • APC Computers &... • Answered on Feb 05, 2022
APC BACK- UPS ES 500 IS NOT SWITCHING ON !
the batteries are bad now. for sure parked like that. kills themn.
2/5/2022 3:55:12 PM • APC Computers &... • Answered on Feb 05, 2022
Model 420 Pro. Why is output only 84 VAC?
no real model told , off rear sticker, (tell sticker model first) 420va no country told no line voltage told in your country Did you buy the ups from wrong country(oops) and it has higher input voltage spec and yours is lower input? (real) nobody can guess what's up there. history and all that and location, voltages are not the same word wide at all nor frequency 50/60Hz did you buy a used UPS. if yes from where ebay, and from wrong country or it ran for years and fails now. or outputs overloaded on it.
2/5/2022 3:47:12 PM • APC Computers &... • Answered on Feb 05, 2022
I have a APC BR600CI-IN ups.its battery not getting charged then i installed a new battery.but create same problem after 2 days.i need to know which component is bad.ic TNY 275 pn?
international model (i) in Europe are you speaking english./? the main board is bad apc does not sell:
  • spare boards
  • nor schematics
  • nor BOM (bills of materials)
they do have service contracts out of warranty .$$$$$
  1. buy new one. whole
  2. buy used one good.
are 2 choices.
2/5/2022 3:29:39 PM • APC Computers &... • Answered on Feb 05, 2022
I have ups from APC (SRT 8000 va) when me make upgrade to the ups the laptop turned off and upgrade does not completed and I can't upgrade ups again because it is turned off, no response ,help
ok , modern like mine but way bigger, 8kw (va) So let me guess you did the UPS FIRMwARE update? I just did min yesterday. no problem UPS wired to internet router. UPS battery must not be bad, <<< read 3 times. all loads removed. no laptop needs UPS a laptop has its own inside. UPS is now dead? as you may know all things made on earth with firmware (or BIOS) when updated, can cause it to brick, vast ways. 10-20 ways on PC but on this UPS mostly 3 ways. not following the manuals instruction step by step, guessing fails battery bad. UPS has other errors, , the log file errors must NONE, using powerchute app to see them. or internet dies mid stride. bad luck there.
2/5/2022 3:26:45 PM • APC Computers &... • Answered on Feb 05, 2022
APC BE500R Back-UPS ES 500 (BPAPWBE500R) UPS System Logo
10 questions posted
Top APC Computers & Internet Experts
Marvin
Marvin
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • APC Computers & Internet
Most Popular Question
no power output
  • Computers & Internet
