20 Most Recent Amana ASD2324H Side by Side Refrigerator Questions & Answers
Request from Amana or an appliance dealer.
Amana... | Answered on Jul 22, 2020
usually in back on top of or near compressor or in the front of fridge u have to remove the panel to see it
Amana... | Answered on Mar 12, 2020
pan is usually located on back or front bottom you may have to remove back or front pANEL TO ACCESS
gently possible soft brush or coil comb
Amana... | Answered on Mar 11, 2020
Hello Dennis;
My name is Peter. I am a retired field service technician.
You did not provide a model number. So, I am going to speak in general. It sounds like you have a bad or stuck contact switch. Or, you ice dispenser handle is broken and activating the dispenser.
You contact switch will look like the following:
There are two slots on the bottom of the dispenser frame for a flat head screw driver. Pop the bottom out. The rest of the frame is held by plastic tabs. Push in the sides to remove the frame.
Ground yourself by touching something that is steal. Static electricity will knock out a board. Remove the board. You will see the contact switch.
Send me the model number and I can be more specific.
Go into the following web site and put in your model number for diagrams and the part number.
Water Filters Lawn Garden Appliance Parts
Amana... | Answered on Jan 08, 2020
Check the plastic drainage tray atop the coils at the bottom underneath. You probably will find a smelly stew waiting to be drained into the sink. Follow up by scrubbing the tray clean.
Amana... | Answered on Dec 02, 2019
That can be two things.
1. Condensation
2. The evaporator is in there behind the grill with a small fan. It freezes up and has a defrost which causes water. That water runs into a drain, your drain is blocked or the fan isn't working.
28 years old, you are due for a new one.
Amana... | Answered on Oct 21, 2019
This appears to be a reference to the defrosting component of a Amana freezer. Let's just assume that it is not a problem with the freezer door seals. (If the seal is not a tight seal when the door is closed, you have melting occurring and the the freezer trying to compensate by refreezing, yielding a lot of icing in the compartment. This is what happens if you over stuff the freezer and the freezer door does not quite close firmly, as well.)
The Amana defrost thermostat might be defective or have become dislodged for some reason. If defective, it would require replacement. But let's say it is not defective. The defroster didn't work when there was too much ice buildup. This could cause the molex connector in the thermostat to contract, breaking the connect activating it. One user "fixed" this problem by putting aluminum foil inside the molex connector.
If the theromostate became dislodged from its "attachment point", one would need to know the model of the freezer know where that point was. https://www.applianceblog.com/mainforums/threads/amana-defrost-thermostat-installation-location.27405/
There are videos describing replacement of the thermostat in some Amana's. You can find such on YouTube. I just can't promise that replacement would fix the problem.
Amana... | Answered on Oct 04, 2019
Check first that there is no leak coming through your gasket a good way is stick a flashlight inside your freezer turn out the lights if you see and beam or light the seal is cracked or must be replaced the check your coils where Freon is supplied if there not cold you must to a pressure test while adding Freon also check for leaks by spraying water on your coils . It's a matter of mathematical elimination also check thermostat if your Amana is under 10 years old look for the fault codes and get someone that can read what faults are being detected
Amana... | Answered on Sep 13, 2019
Probable failure. A common problem with icemakers.
Amana... | Answered on Sep 06, 2019
Possibly the filter both air and water. Make sure the lines aren't frozen. If the unit has an ice maker you can warm the lines with a blow dryer ( warm on low fan) make sure it's level. Is the trim gasket around the door worn?
Amana... | Answered on Jul 25, 2019
Theres a few solutions that could fix this. 1st I would let the unit thaw out could have ice built up on the air passage that wont allow the air to travel freely. Some caused by not having a good seal around the door.
Amana... | Answered on Jun 15, 2019
Always fault find and repair the fault before replacing a board. Without sight of the machine, I can only guess at the compressor.
Amana... | Answered on Jun 08, 2019
Amana ASD2324H Side by Side Refrigerator Logo
0 questions posted
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
old 28 year amana refrigerator leaking
  • Refrigerators
