20 Most Recent Amana ASD2622HRQ Side by Side Refrigerator Questions & Answers
Are you saying your freezer coil is solidly frozen?
Amana ASD2622HRQ... | Answered on Jan 21, 2018
Hello Racinfrogs,
You are most likely looking at a serious FROST blockage...
FIRST thing to check... YOUR DEFROST pan...
If dry... you have found your TROUBLE..
A serious FROST
blockage can be caused by SEVERAL
air intrusion issues... Ice cube stuck: holding chute door open... or a pizza box holding any door ajar... Perhaps even a failed (or poorly aligned) DOOR GASKET...
(all these will be burdening your defrost pan: lots of water)
FINALLY... and very common
A DEFROST CIRCUIT FAILURE.
(this will be manifested by a DRY defrost pan)
Easiest... Part to check & change
Your REFRIGERATOR has a defrost timer...
Check here for replacement part (wp67001036)
and INSTRUCTIONAL VIDEO...
http://www.appliancepartspros.com/whirlpool-timer-defrost-wp67001036-ap6010261.html
In addition to their instructions.. I always SUGGEST
you should take pictures and notes of what COLOR
wire goes where... BEFORE getting in trouble...!!
There are only 2 (two) other parts to the defrost circuit...
EASY once you understand...
- Thermal switch to keep defrost temperature v-low
- heater element (ungoverned can ruin food/plastic).
Hope this helps... ELSE comment me
back BEFORE getting in trouble.
Pricewise (using part number) also check eBay
Genuine Amana Whirlpool Defrost Timer 67001036 WP67001036 PS2063117 eBay
Carnac the Magnificent
Amana ASD2622HRQ... | Answered on Sep 21, 2017
These are always going bad...it is the defrost thermostat thats go bad or your fan motor..the defrost thermostat is located behind cover in freezer...one side is connected to your heater and the other is the line wire....you can actually bypass the defrost t/s just to check it, however, check for voltahhhhge at fan first
Amana ASD2622HRQ... | Answered on Jan 20, 2011
you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Amana ASD2622HRQ... | Answered on Jan 05, 2011
The bar should be down in ice making mode, if you ever noticed the bar rises upon ejection of ice cubes from the tray, and falls to its postion hovering above the ice bin, as the bin gets full the bar cant lower to the postion indicating a full bin and it willl stop ice making.
Amana ASD2622HRQ... | Answered on Dec 27, 2010
Your defrost heater or defrost thermostat may be bad. Test defrost heating element for continuity. If heater is good, replace the defrost thermostat. In most cases, replacing both is advisable.
Amana ASD2622HRQ... | Answered on Dec 17, 2010
Abesolutely a bad defrost heater. it is too weak to defrost the ice completely, therefore it falls off the coils and freezes on the drain tray. If you dont want to replace the heater you can also just install a drain tube heater that wires into the evaperator fan, it will run constantly as the fan does to keep water from freezing in the tube or tray. All parts can be purchased at http://www.reliableparts.com/ using your model number.
Amana ASD2622HRQ... | Answered on Nov 30, 2010
Can't remove it just clean by hand.
Amana ASD2622HRQ... | Answered on Nov 01, 2010
auto defrost might be on. turn the dial until the compressor clicks on. it's usually located under the fridge behind the front grate.
Amana ASD2622HRQ... | Answered on Aug 06, 2009
usually in back on top of or near compressor or in the front of fridge u have to remove the panel to see it
Amana... | Answered on Mar 12, 2020
pan is usually located on back or front bottom you may have to remove back or front pANEL TO ACCESS
gently possible soft brush or coil comb
Amana... | Answered on Mar 11, 2020
Hello Dennis;
My name is Peter. I am a retired field service technician.
You did not provide a model number. So, I am going to speak in general. It sounds like you have a bad or stuck contact switch. Or, you ice dispenser handle is broken and activating the dispenser.
You contact switch will look like the following:
There are two slots on the bottom of the dispenser frame for a flat head screw driver. Pop the bottom out. The rest of the frame is held by plastic tabs. Push in the sides to remove the frame.
Ground yourself by touching something that is steal. Static electricity will knock out a board. Remove the board. You will see the contact switch.
Send me the model number and I can be more specific.
Go into the following web site and put in your model number for diagrams and the part number.
Water Filters Lawn Garden Appliance Parts
Amana... | Answered on Jan 08, 2020
Check the plastic drainage tray atop the coils at the bottom underneath. You probably will find a smelly stew waiting to be drained into the sink. Follow up by scrubbing the tray clean.
Amana... | Answered on Dec 02, 2019
That can be two things.
1. Condensation
2. The evaporator is in there behind the grill with a small fan. It freezes up and has a defrost which causes water. That water runs into a drain, your drain is blocked or the fan isn't working.
28 years old, you are due for a new one.
Amana... | Answered on Oct 21, 2019
This appears to be a reference to the defrosting component of a Amana freezer. Let's just assume that it is not a problem with the freezer door seals. (If the seal is not a tight seal when the door is closed, you have melting occurring and the the freezer trying to compensate by refreezing, yielding a lot of icing in the compartment. This is what happens if you over stuff the freezer and the freezer door does not quite close firmly, as well.)
The Amana defrost thermostat might be defective or have become dislodged for some reason. If defective, it would require replacement. But let's say it is not defective. The defroster didn't work when there was too much ice buildup. This could cause the molex connector in the thermostat to contract, breaking the connect activating it. One user "fixed" this problem by putting aluminum foil inside the molex connector.
If the theromostate became dislodged from its "attachment point", one would need to know the model of the freezer know where that point was. https://www.applianceblog.com/mainforums/threads/amana-defrost-thermostat-installation-location.27405/
There are videos describing replacement of the thermostat in some Amana's. You can find such on YouTube. I just can't promise that replacement would fix the problem.
Amana... | Answered on Oct 04, 2019
Amana ASD2622HRQ Side by Side Refrigerator Logo
17 questions posted
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
am dennis unit leaks water from
  • Refrigerators
