20 Most Recent Amana ABB2524DE Bottom Freezer Refrigerator Questions & Answers
Check the top of the inside of the fridge. There is usually a flap door mechanism that sometimes falls off or sticks. This regulates the temp in the fridge.
Amana ABB2524DE... | Answered on Jan 29, 2014
hi.a bit vague but i would check the door hinge bushes first.i'm assuming door seal ok.hope this helps.Ali
Amana ABB2524DE... | Answered on Jul 04, 2012
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Amana ABB2524DE... | Answered on Nov 08, 2011
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one.
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Amana ABB2524DE... | Answered on Aug 15, 2011
I did my own search for the same problem and saw Dougs question and lack of a solution. I have the same sagging door problem and was looking for a fix.
First, when I removed the weight of the items from inside the door, the door closes properly. This means that the door is not very sturdy and cannot hold the weight of items placed on door shelving. There are NO adjustment mechanisms on the door hinges either. Bad on Amana. The GOOD NEWS is that I fixed the problem.
Take out all items from the door shelves. I removed the top hinge with the door closed to keep it from falling. I took the door off and placed it on the floor. The lower hinge has a plastic pivot over a steel pin - remove that for a moment. Place steel washers over the steel pin - about .080" or so thickness. Replace the plastic pivot. Replace the door. Add the normal weight of items back on the door shelves. The door closes perfectly. At least until the door sags again and I'll need to add another shim.
Amana ABB2524DE... | Answered on Aug 06, 2011
HI,IF THE FREEZER IS BUILDING ICE ON EVAP COVER THAT IS NOT DEFROSTING PROPERLY,REPLACED THE CONTROL BOARD AND DEFROST B-METAL TO REPAIRD THE PROBLEM..
Amana ABB2524DE... | Answered on Jul 05, 2011
Hello, Thank You for using FixYa. I will be helping you today. I would check the fill tube comming thru the back wall to see if it froze up. You can pull it out from the back. Also make sure the water is on all the way. There may be a stuck ice cube. Also the arm should be in the down position. Hope this helps.
Thank You and please rate my answer if it was helpful..
Amana ABB2524DE... | Answered on Jun 09, 2011
dont understand what your saying try again, ill try to help.
Amana ABB2524DE... | Answered on Feb 25, 2011
Hi and welcome to FixYa, I am Kelly.
There are 4 models of the unit and the last digit indicates color that being an B, S, Q or W. For reference purposes I will use the B model. Having said that... things that can cause your symptom are:
1. The control board Item 5 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167295&diagram_id=28326675#d28326675
2. The defrost themostat that is the very last item on this page: (no item number listed)
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167295&diagram_id=28326676#d28326676
3. The defrost heating element Item 15 above link.
4. The termistor Item 22 of this link:
5. The PTC relay / overload protector or the run capacitor items 10 and 11 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167295&diagram_id=28326674#d28326674
6. The compressor Item 8 of the above link:
Those are all things that can cause your problem. It takes component testing and replacement to isolate which one of them is causing the problem.
For example... if the unit is in defrost the compressor does not run. If the defrost thermostat has failed it will never terminate the defrost cycle so the lights will be on but the compresser will never start. Also.. if the heater has failed... the Freezer will have to warm up to 60 deg F before the compressor will restart. If the compressor is trying to start about every 5 to 6 minutes the PTC / overload protector has failed. When this happens the PTC / Overload and the run capacitor are all replaced at the same time. (<- before changing these parts if the compressor is HOT unplug the unit for 20 minutes and wait for the comressor to cool down then try and restart it) A bad control board.... or an open /shorted compressor winding can cause a dead unit. There are other examples... but these are the most common. Just a note about your unit if the fans are on and the compressor is NOT running you need to look at the compressor only as where the problem lies. (relay overload cap and or compressor / compressor wiring).
You can try doing a manual defrost by directing an external fan into the freezer compartment for 2 hours. (Makes a water mess) In your case your trying to get the defrost bi-metal thermostat to 60 Deg F so that the signal to start the compressor is present. (provided the defrost thermostat is good) Other than that the only option is to troubleshoot using this wiring diagram:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28326683&pkw_=basket&model_id=5167295&NewWindow=1
Thanks for choosing FixYa,
Kelly
Amana ABB2524DE... | Answered on Feb 24, 2011
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Amana ABB2524DE... | Answered on Feb 06, 2011
Check freezer fan is working.If ice formed over freezer fan by working. It's a common problem due to irregular defrosting. Keep freezer setting temp at 5 degree. And check defrost timer, thermostat,heater are working properly.
Turn timer with small tip screw driver to shut off fridge. If not shut off, replace timer. Turn counter clockwise defrost thermostat. If fridge not shuts off replace defrost thermostat.Check heater by join the 2 wires in the defrost thermostat. And after 1 minute, unplug power and keep your arm on heater. If it's warm heater is o.k. Otherwise, replace heater.
Once heater starts work at regular interval controlled by thermostat and timer, defrost will be good and effective cooling will also be in fridge compartment.
Amana ABB2524DE... | Answered on Jan 30, 2011
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
dffg
Amana ABB2524DE... | Answered on Sep 29, 2010
If your refrigerator is not cooling, the problem could be any of the following, follow the steps below one after the other to fix the problem of your refrigerator not cooling.
First of all, the most simplest thing to do is to check the temperature. It might have happened that the temperature control may have been turned off unknowingly, which is the reason for the problem. So if that's the issue, just set the refrigerator at 37 degrees and you are all set.
Poor coiling leads to a heavy frost build up on the evaporator coils. A frost build up, specially on the ceiling of the freezer, is a sign of problem in the self defrosting system or damaged gaskets of the doors. Therefore, check if the refrigerator is facing such a problem and defrost the refrigerator. It would not cool well if the defrosting is not happening properly.
A dirty condenser may be the culprit for your refrigerator not cooling well. What will happen in case if the condenser is dirty is that it will cut off the extra load. That work is done by the thermostat on the side of the compressor in case the refrigerator heats more than usual. To rectify this problem clean the condenser coils using the vacuum cleaner. These are either behind or beneath the refrigerator
In case the refrigerator is not leveled, that too can lead to the refrigerator not cooling properly, because if the level is not right, the door of the refrigerator may not close correctly, causing cooling problems. If this is the case, it might be necessary to ensure that refrigerator is at level and is slightly tilted back. Do some adjustment to get that correct level using a wooden block or see if the screws on the leveling legs need some looking into.
Check out the door seal. If the door seal is worn out, it will definitely result in frost build up and that won't allow the door to close properly, thus the problem of refrigerator not cooling. In addition to that there can be a problem in the door even if the level and other things are fine. You would need something to do about the door then. May be loosen the hinges and fix them in order to get the correct position of the door. Eventually tighten the hinges.
The food and freezer sections will go dysfunctional if the evaporator fan is not working properly. This is because then there will be no airflow to the freezer or the other sections of the refrigerator. Confirm if both the fans are working well by listening to the sound emitted by them. There is a possibility that one may work and the other wont. For that, may be you would have to look for a blockage or something in the one which is not working. Even after doing this you do not find any problem in the fan, you may need to replace it. This are are the general procedure for troubleshooting refrigerator not cooling. with all this, you should be able to identify and fix the problem.
Take care.
Amana ABB2524DE... | Answered on Aug 24, 2010
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Amana ABB2524DE... | Answered on Nov 27, 2009
Hello Dennis;
My name is Peter. I am a retired field service technician.
You did not provide a model number. So, I am going to speak in general. It sounds like you have a bad or stuck contact switch. Or, you ice dispenser handle is broken and activating the dispenser.
You contact switch will look like the following:
There are two slots on the bottom of the dispenser frame for a flat head screw driver. Pop the bottom out. The rest of the frame is held by plastic tabs. Push in the sides to remove the frame.
Ground yourself by touching something that is steal. Static electricity will knock out a board. Remove the board. You will see the contact switch.
Send me the model number and I can be more specific.
Go into the following web site and put in your model number for diagrams and the part number.
Water Filters Lawn Garden Appliance Parts
Amana... | Answered on Jan 08, 2020
Check the plastic drainage tray atop the coils at the bottom underneath. You probably will find a smelly stew waiting to be drained into the sink. Follow up by scrubbing the tray clean.
Amana... | Answered on Dec 02, 2019
That can be two things.
1. Condensation
2. The evaporator is in there behind the grill with a small fan. It freezes up and has a defrost which causes water. That water runs into a drain, your drain is blocked or the fan isn't working.
28 years old, you are due for a new one.
Amana... | Answered on Oct 21, 2019
Amana ABB2524DE Bottom Freezer Refrigerator Logo
27 questions posted
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
amana abb2524dew frig ice maker not
  • Refrigerators
