20 Most Recent
ASUS P4P800-E Deluxe Motherboard Questions & Answers
My computer (3.0 GHz Pentium
Checked your RAM chips? Remove them and boot up and see if it will beep. If you have another DVD drive, swap it and try again. The board battery rarely goes, and only change it when it is not keeping the date/time etc, it won't help in outputting video.
Hi,my computer stop working suddenly,and
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
When installing the motherboard, the fans begin to
test your PSU power supply unit it might be faulty and the leads tha attach to your fan s power supply including electrical extensions also
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
I have more then ten fsus P4P 800 SE, same problem
get these boards to mnufacturer service center
or tell the problem indetail as
1 if the boards are starting on
2. did u check the beep with Rams getting out of board
3. if the monitor/lcd data cable is right
4. monitor/lcd is faulty?
solution lies in above questions
please don't forget to give me all thumbs
have a nice day
AGP card not working. I replace another one and
Have you entered bios on start up.
In bios you usuly have the choise to chose between AGP or PCI graphic card so i think that's where the problem is.
Usually you have to hit the Del(delete) button on start up an go to "save & exit" when you`r done.
Read the user manual for the main-board if needed!
I`l hope this will fix it.
The bios is not installed
Go to BIOS, under Advanced > PCI Configuration. Disable Onboard ATA
device if you're not using RAID. Also, make sure under Boot Menu that
Other boot device do not show SCSI/Onboard ATA.
Hope that helps.
I get a Post audio message on boot up/but no bootup
i have just thrown out 3 ASUS boards for various problems. they seem to last approx 18months before they die.
video output goes wrong, cpu socket errors, all sorts of problems and a rubbish tech support at ASUS does not help.
WONT POWER ON!
it can be the issue of faulty power supply just check out the fan in the power supply is it moving properly or not if it is getting stopped the power supply can be faulty.also check out the fan on mother board processor it can also be the issue of not getting the pc on.also check out the CMOS battery.it may be faulty.just remove and reinsert the battery again and check also check out replacing the battery.
I get a message over the speakers System failure from CPU overclo
Hi there
Try resetting the CMOS either by removing the battery from the motherboard for 20 mins and make sure the power cord is removed from the back of the machine. When you put the battery back you will have to set the time and date again
Good luck and kind regards
