20 Most Recent
AOpen s661FXm-7US (918EM10S6G) Motherboard Questions & Answers
Pdf file for motherboard open MODEL; s661fxm
lost the manual and CD sure. like all this oldthere are 2 choices..1: google for it, find it. if lucky. that old.the maker ended all support in 2011, and for sure this.google finds this (7ziped compressed)PDF inside and good.https://soggi.org/files/motherboards/manual/aopen/s661FXmFSN.7z2: go here and find it.to the waybackmachine to find the dead. (graveyard)2003 to 2005 made, guess at 2004SIS junk now,chipsets. dead now 2 ways, SIS and Aopenhere it is in the grave 2005, (weak and not complete)https://web.archive.org/web/20060418170647/http://global.aopen.com.tw/Products/mb/s661FXm-7US.htm
5/28/2022 6:06:00 PM •
AOpen...
Answered
on May 28, 2022
My board is coming on
Hello there,
Step 1: Check all connections from the display to the PC
Step 2: Make sure the button for the Display if pushed to the on
Step 3: if you have another display you can use for testing try it
starter Steps there are more let me know if they fail and we keep going thank you and don't forget to Rate
1/26/2011 1:11:28 AM •
AOpen...
Answered
on Jan 26, 2011
I turn on my computer
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
10/10/2010 1:06:23 AM •
AOpen...
Answered
on Oct 10, 2010
I have inserted a 1 GB mamory modual and the
No jumpers or switches need to set. If your going to upgrade/change your memory, just make sure that the memory your're going to insert are compatible with your motherboard. Check the system bus of your memory slots if what are the maximum system bus can support of that motherboard. Like example; DDR PC266 to PC400 or PC400 to PC800, make sure that you are not exced the maximum requirements of the memory for your motherboard it is because they cannot recognize your memory.
6/5/2010 8:42:03 AM •
AOpen...
Answered
on Jun 05, 2010
What is the wireing guide for the A Open
Hi markmincel,
It wasn't easy but you can find the operating manual for this board
HERE. Go to the bottom of the page and enter the secret code.
Good Luck,
Mark
11/20/2009 1:00:57 AM •
AOpen...
Answered
on Nov 20, 2009
No sound
i have the same problem u just check out ur device manager what it shows whether what is the status of ur hd dudio if it is working or not if not enable enable it chekc ur bios setup also and all fail then format again and reinstall ur operating sysm hope u get rid off ur problem
11/30/2008 10:26:16 AM •
AOpen...
Answered
on Nov 30, 2008
Start up loop
rest your bios settings put away your vcmos for 15 minutes also u can rest your bios with jumper settimgs near ly the cmos cell set it in 2-3 positon then start the computer then again set in its original position.
11/12/2008 7:07:06 AM •
AOpen...
Answered
on Nov 12, 2008
Fsp250-60 power supply
learn to google, old PCs ,
as yours seems to be t ATX form factor
and 250w to 500 watt ATX PSU that has bundles of IDE 4pin molex connecters there will work.
legacy PSU.
any will work. that era (IDE-PATA)
Aopen 40x12x48x compact disc CD re-writable not working what cables do i need to run it?
the PC is secret, model.
NO PC told\no CD drive model told.no told how it connects at all , IDE, SATA or Esata or USB.?you do know right,that many laptop users today have CD drive there and it will never fit now in modern thin casesand they buy a external DVD(CD or bluray) drive and plug it in...for that reason and is more easy,look Ma' no screws to fiddle.NO PC TOLD (Aopen what modeL?)NO OS toldand no DVR drive model told.impossible this.?if the drive is internal to PC,laptops just slide in, and connectdesktop, 2 cables, 15pin power, and SATA 7 pin cables (sold in stores even target or walmart)desktop relics that most Aopen are, use IDE (PATA)40- pin ribbon (pata-IDE) and 4 pin molex power (PATA)IDE parts are only sold online, there are 20 year relics. (2001 SATA was . and was wild fire success and is best )
