20 Most Recent
Brother CS-6000 Computerized Sewing Machine Questions & Answers
Brother CS6000 computerized machine bobbin case moves and locks up
The Black bobbin case more than likely is not installed correctly.
The machine just won't sew with it rattling about in it's space.
Machines do have levels of quality. Proper maintenance is a must for any busy sewing machine who's owner is expecting a trouble free use.
Cheers,
Embroidery Services
San Diego, CA
My brother exedra e-40 #db2-b737-413
- In the event that changing the needle didn't determine the issue, have a go at rethreading the machine, guaranteeing legitimate pressure, and cleaning the bobbin region for any build up or garbage. On the off chance that the issue continues to happen, consider counseling the machine manual or looking for proficient help.
Brother XL5600 is not stitching properly and dropping stitches?
need to check the hook timing.
put it in zig zag, no fabric, turn the hand wheel to you slowly.
check the needle when it is coming back up, is the hook picking up the thread? if yes continue to check the next side, so if you check the left side then check the right. if any side its not picking up the thread then the timing is off and need to be retimed
I have a Brother Lock Serger. 1034D The Pressure foot Lever just spins around.
If you can remove the cover on the left side you will see the presser foot bar. On the bar there will be a screw that may be loose. Turn the handwheel until the needle is all the way down and lift the foot manually until just before it makes contact with the needle clamp and tighten the screw on the presser foot bar.
That should do it.
