20 Most Recent
Brother LB-6800PRW Project Runway Limited Edition Combination Machine Questions & Answers
How to digitize an image for use on a Brother LB-6800
Yes. PE-DESIGN is one of the programs allow you to transform pictures/images into embroidery. There are companies that will do it for you if you want only particular pictures done so that you won't have to purchase the program. There are other programs available and some of them are very expensive. I think that PE-DESIGN by Brother is one of the more inexpensive brands that are very good. Maybe I can help you if you send me a photo of what you would like to transform:
[email protected]
7/2/2016 6:01:56 PM •
Brother...
Answered
on Jul 02, 2016
Brother LB6800PRW Bobbin Tension?
I suggest having the top tension checked by a sewing machine technican,, and since the bobbin case screw is painted with green ,, I suggest having it checked also to make sure the tension is correct on it. also make sure the bobbin is inserted correctly--counter clock-wise..
12/18/2014 3:47:51 PM •
Brother...
Answered
on Dec 18, 2014
My brother exedra e-40 #db2-b737-413
- In the event that changing the needle didn't determine the issue, have a go at rethreading the machine, guaranteeing legitimate pressure, and cleaning the bobbin region for any build up or garbage. On the off chance that the issue continues to happen, consider counseling the machine manual or looking for proficient help.
Brother XL5600 is not stitching properly and dropping stitches?
need to check the hook timing.
put it in zig zag, no fabric, turn the hand wheel to you slowly.
check the needle when it is coming back up, is the hook picking up the thread? if yes continue to check the next side, so if you check the left side then check the right. if any side its not picking up the thread then the timing is off and need to be retimed
