20 Most Recent Bissell Powersteamer 1694 Upright Vacuum Questions & Answers
0answers
Brush doesn't turn
Be the first to answer 12/26/2013 10:37:03 PM • Bissell... • Posted on Dec 26, 2013Be the first to answer
Broken part which holds roller brush in place
Brush roll retainer needs replaced.
11/3/2013 2:00:28 PM • Bissell... • Answered on Nov 03, 2013
My bissell shampooer 1694 model brushes will not
mine rotates but not smooth...as the part on one side of the roller brush seems to be broken
11/2/2013 5:01:09 PM • Bissell... • Answered on Nov 02, 2013
1694 need instruction manual
I have the instruction manual. The part is not listed.
11/2/2013 4:59:32 PM • Bissell... • Answered on Nov 02, 2013
Will not shampoo
will not roll smoothly
11/2/2013 4:58:51 PM • Bissell... • Answered on Nov 02, 2013
How to use a bissell power steamer model 1694
You could download the manual which would have all the details :
http://www.retrevo.com/support/Bissell-1694-W-Vacuums-manual/id/10039bh339/t/2/
You need to click on ' Download the document '. Once clicked, it would take you to the new page. You need to go for option 2. Enter the string of numbers for verification and click on download now. A pop up would be there. Save the file on the desktop. Be advised that you need to have an acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
8/24/2011 2:43:06 PM • Bissell... • Answered on Aug 24, 2011
0answers
How do you change the belt
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
9/6/2010 1:57:39 PM • Bissell... • Answered on Sep 06, 2010
2answers
I need insructions to replace
See the image below
1. Turn off power switch and unplug from the outlet.
2. Using a Flat head screw driver, insert the blade end into the lower slot of the belt access door to release the lower snap. Insert the blade end to the upper slot to release the upper snap.
3. Examine the belt for breakage. You should be able to see the pump belt looped around the motor shaft.
4. Replace if its broken or missing.
5. Once completed replacement return back the belt access door and power on the unit.
If you still have some questions just post back.
Please do rate my solutions.
Thank you for using Fixya.
Alp
9/6/2010 6:24:37 AM • Bissell... • Answered on Sep 06, 2010
2answers
Bissell powersteamer powerbrush starts up
Select the setting on the outside of the formula tank. The choices are "high traffic," "normal" and "water rinse." The steamer will mix the appropriate amount of formula with the water in the tank. Choose the "floor cleaning" setting on the tools dial that's located to the left of the tank. Plug the steamer into an electrical outlet. The power switch is on the back of the machine handle; turn it to "on. if no improvement, check to ensure the openings are not stuck with debris, also, check the cord to see that it is not bad, if it is, replace the cord.
Take care.
7/25/2010 11:25:43 PM • Bissell... • Answered on Jul 25, 2010
Changing a drive belt
Turn the unit upside down and on each side of the roller brush is a red piece of plastic with screws remove and take off roller then you will see the belt drive stem place around stem and on roller and pop back in, Reassemble. Steve
6/7/2010 2:41:35 AM • Bissell... • Answered on Jun 07, 2010
Bissell Powersteamer 1694W won't extract water
Check your re-assembly.
Have you missed a pipe connection somewhere?
5/1/2010 8:07:19 PM • Bissell... • Answered on May 01, 2010
Need to replace belt for brush
Hi there SmartAlec from NelsonVacuums.com.au here. If you are in Australia i can help you get this part. Just go to our home page and use the contact us link. I actually just ordered some of these belts so will have them in a day or so. Regards Alec
Happy Vacuuming
4/12/2010 8:41:43 AM • Bissell... • Answered on Apr 12, 2010
Bissell Powersteamer 1694 Upright Vacuum Logo
Popular Tags
37 questions posted
Top Bissell Vacuums Experts
Marvin
Marvin
David Shaub
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Bissell Vacuums
  • Bissell Vacuums
Most Popular Question
need insructions replace
  • Vacuums
