20 Most Recent ASUS V9520/TD GeForce FX 5200, Graphic Card Questions & Answers
Asus website has it
ASUS V9520/TD... • Answered on Apr 20, 2014
http://download.cnet.com/copy-of-g02-cd31/3000-2112_4-172989.html
http://download.cnet.com/asus-v9900-v52-16/3000-2108_4-67428.html
http://download.cnet.com/asus-v9520-video-suite/3000-2108_4-68312.html
http://download.cnet.com/asus-v9520-x-v62/3000-2108_4-65504.html
if these packages are not the right http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for (be precise)exceptions are numbers and ) / - also the download software finder under that there will be a list place a tick in the box of any one you want/need all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
ASUS V9520/TD... • Answered on Sep 02, 2011
Hello jean ,
I found a Vista 64-bit driver here : http://www.omegadrivers.net/index.php?option=com_phocadownload&view=file&id=14:nvidia-omega-drivers-1.169.25&Itemid=97
Windows 7 should follow soon but you could give this one a try first .
Best regards ,
fanaudi
ASUS V9520/TD... • Answered on May 22, 2011
Welcome to fix ya
Hi you can download the drivers here
http://www.nvidia.com/object/winxp_175.19_whql.html
Just remember to choose the appropiate operating system
hope this helps. if this solves your problem please dont forget to rate
ASUS V9520/TD... • Answered on Apr 25, 2011
u can download the driver here: http://www.softwarepatch.com/utilities/nvidia-geforce-fx-5200.html
ASUS V9520/TD... • Answered on Dec 26, 2008
Download Drivers Here is a link to download Nvidia drivers
ASUS GeForce... • Answered on Feb 07, 2016
There should be a model number on the board somewhere. A search of the model number would be better. You may have to remove a fan to see the chipset, then go to the Asus website and look up the video cards that use the same chipset. Graphics Cards ASUS
ASUS GeForce... • Answered on Feb 20, 2015
Did you try to play games for a long time, with the stock cooler. i'm amazed about all the gammer which are still using stockcooling and the teperature stays warm for 5 hours. And if i say they need to watercool it, just like you cpu and memory, because high temps degrease 1. the lifespan of your gear ( especially mb with cheap capacitors) enemoursly, but they overclock the graphiccard at the same time , while the effectivity decreases , caused by too warm components, they want also higher ratings from the card by overclocking. That's why i never by second hand cards or mb's or cpu's. Does the card still work; if not, does it smell burning? and did it broke, while gaming?????
ASUS GeForce... • Answered on Jul 22, 2014
What operating system are you running on the PC? Do you have the appropriatre drivers? Have you loaded them?
ASUS GeForce... • Answered on Mar 10, 2014
Check very well that the connection of the connectors is right: push the videocard lightly onto the motherboard, with a little wriggling. Maybe remove and clean connectors with alcohol and then reput it in. Also check the powerline connector very well. if this is of no help, I am afraid it is broken.
ASUS GeForce... • Answered on Feb 07, 2014
Hi , I suggest to check for any thermal issues including condition of the video card fan / heat sinks ie dust , If supported you can run a LINUX disk like Ubuntu in live / try mode If video works ok , then most likely a Windows environment incl hardware conflict or virus / driver corruption issue , but if not then most likely a video card hardware issue like bad card cooling fan or excessive dust - thermal shedding issue or card bios/chipset fault If a likely software issue then uninstall and then reinstall the video card Consult ASUS or Nvidia support The procedure is something like this Onboard video support ? yes uninstall the video card driver and any video vendor configuration applets Uninstall video card in device manager if still present. Shut down and remove mains power cable remove the hardware video card , (using anti static electricity procedures) Attach onboard video to display Power up and enter and configure BIOS setup if required, ie 1st seek onboard video Bootup to Windows Install the onboard video device using Windows plug&play default driver executed during booting Restart Confirm working ok Update the chipset driver (inf) if applicable, restart Shutdown Reinstall the hardware video card Attach to display Reconfig BIOS setup if required Start to install default driver Install video driver / update from card default using a known good driver whose setup file has been previously downloaded restart and test Hope this helps
ASUS GeForce... • Answered on Dec 07, 2013
When you say "gpu wont work" what do you mean? What does it do or not do? Thanks
ASUS GeForce... • Answered on Nov 20, 2013
Try the ASUS website for the driver. If that is what you are looking for. (It even tells you in the information you provided.)
ASUS GeForce... • Answered on Sep 20, 2013
ASUS V9520/TD GeForce FX 5200, Graphic Card Logo
11 questions posted
Top ASUS Computers & Internet Experts
Roy May
Michael Thomas
Michael Thomas
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
GeForce ASUS
  • GeForce ASUS
Most Popular Question
need driver
  • Computers & Internet
