20 Most Recent ASUS EN7300GS/HTD GeForce 7300 GS, PCI Express Graphic Card Questions & Answers
I have provided a link below for your Asus model graphic board.
Please copy and paste the link into your broswer that will take you to the Asus support page for your model graphics board.
Select the operating system you have and to go the the page that will provide the downloads your driver and information about your Asus model EN7300GSHTD graphics board.
Good Luck
http://www.asus.com/Graphics_Cards/NVIDIA_Series/EN7300GSHTD_Series/
ASUS... • Answered on Sep 01, 2011
Hello sifian_786, did you try to uninstall old video driver and restart computer and go to nvidia website and download latest driver for you video card and install, restart computer this should solve problem you have, are you trying to run dual LCD monitors ?
ASUS... • Answered on Nov 26, 2010
are they 2 different graphics cards? If so then no, you can use both but if you want SLI or ATI then you MUST have 2 of the same cards or cards that are compatible together.
To find out whats compatible go to the manufacter's website and there should be a section for SLI and a chart for compatibility when i was on Nvidia i know there was a chart for this but can't find a link. Sorry just use google to search for "compatible vga cards with XXXXXXX" should help or google a chart for this.
check out my site!! http://ctrlr4repair.webs.com
ASUS... • Answered on May 05, 2010
When updating drivers it is alsowise to visit game manufacturers site and see if any patches are available or if there are other solutions to resolve known bugs.
ASUS... • Answered on Mar 20, 2010
I think the game you played has made your graphics card to fail. The graphics card has now be out of order. Consult your dealer for a replacement.
ASUS... • Answered on Aug 15, 2009
in safe mode your "graphics accelerator" doesnt kick in, it runs a slow standard VGA commands. If your card was damaged by usualy overheating or just itself (bad luck, happened to me on 6600gt) it will die either quick or slowly. Slowly means, first "Direct 3D" will show rubbish on screen, the "OpenGL" and later even in windows it displays lines and freezes. After that, you cant even go to BIOS cause if freezes 5 secs after boot. Mine died that way. TRY another card, cheapest u can get or borrow but the same port AGP or PCX, whiever u have. If all is ok, the card is gone. (sounds like it 90%)
ASUS... • Answered on Jan 26, 2007
Download Drivers Here is a link to download Nvidia drivers
ASUS GeForce... • Answered on Feb 07, 2016
There should be a model number on the board somewhere. A search of the model number would be better. You may have to remove a fan to see the chipset, then go to the Asus website and look up the video cards that use the same chipset. Graphics Cards ASUS
ASUS GeForce... • Answered on Feb 20, 2015
Did you try to play games for a long time, with the stock cooler. i'm amazed about all the gammer which are still using stockcooling and the teperature stays warm for 5 hours. And if i say they need to watercool it, just like you cpu and memory, because high temps degrease 1. the lifespan of your gear ( especially mb with cheap capacitors) enemoursly, but they overclock the graphiccard at the same time , while the effectivity decreases , caused by too warm components, they want also higher ratings from the card by overclocking. That's why i never by second hand cards or mb's or cpu's. Does the card still work; if not, does it smell burning? and did it broke, while gaming?????
ASUS GeForce... • Answered on Jul 22, 2014
What operating system are you running on the PC? Do you have the appropriatre drivers? Have you loaded them?
ASUS GeForce... • Answered on Mar 10, 2014
Check very well that the connection of the connectors is right: push the videocard lightly onto the motherboard, with a little wriggling. Maybe remove and clean connectors with alcohol and then reput it in. Also check the powerline connector very well. if this is of no help, I am afraid it is broken.
ASUS GeForce... • Answered on Feb 07, 2014
Hi , I suggest to check for any thermal issues including condition of the video card fan / heat sinks ie dust , If supported you can run a LINUX disk like Ubuntu in live / try mode If video works ok , then most likely a Windows environment incl hardware conflict or virus / driver corruption issue , but if not then most likely a video card hardware issue like bad card cooling fan or excessive dust - thermal shedding issue or card bios/chipset fault If a likely software issue then uninstall and then reinstall the video card Consult ASUS or Nvidia support The procedure is something like this Onboard video support ? yes uninstall the video card driver and any video vendor configuration applets Uninstall video card in device manager if still present. Shut down and remove mains power cable remove the hardware video card , (using anti static electricity procedures) Attach onboard video to display Power up and enter and configure BIOS setup if required, ie 1st seek onboard video Bootup to Windows Install the onboard video device using Windows plug&play default driver executed during booting Restart Confirm working ok Update the chipset driver (inf) if applicable, restart Shutdown Reinstall the hardware video card Attach to display Reconfig BIOS setup if required Start to install default driver Install video driver / update from card default using a known good driver whose setup file has been previously downloaded restart and test Hope this helps
ASUS GeForce... • Answered on Dec 07, 2013
When you say "gpu wont work" what do you mean? What does it do or not do? Thanks
ASUS GeForce... • Answered on Nov 20, 2013
Try the ASUS website for the driver. If that is what you are looking for. (It even tells you in the information you provided.)
ASUS GeForce... • Answered on Sep 20, 2013
ASUS EN7300GS/HTD GeForce 7300 GS, PCI Express Graphic Card Logo
Popular Tags
14 questions posted
Top ASUS Computers & Internet Experts
Roy May
Michael Thomas
Michael Thomas
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
GeForce ASUS
  • GeForce ASUS
Most Popular Question
download driver asus en7300gs htd 256m
  • Computers & Internet
