20 Most Recent
Blueair Blue Air 402 Smokestop Particle Filter Air Purifier Questions & Answers
CAR DIE WHEN SLOW DOWN OR STOP AND LET GO THE GAS
i went to my mechcanic the same day my engine started to make the same loud noise that you are talking about. he said that it was the flex pipe. just this morning (5:30am 8/3/09) i went to dunkin donuts for my morning coffee and while waiting in line, my car just stopped running. like you said, when you take your foot off the gas and press the break, the car stops. no doubt about it, it is the flex pipe. im sure by now you got your car fixed but i thought that i'd share my car troubles with you :)
Car dieing
You may have a Vacuum Leak, Throttle Position Sensor may be bad, and the MAP Sensor. Those are know to go on the 3.1L Chevy Lumina's. Thank you for using Fix Ya! Don't forget to rate the overall rating of this answer. Good Luck.
Dead
check power outlet / test the Blue air power cable w/tester continuity , switch on and off, tester move forward and reverse meter means good plug/ if does not move the fuse of the unit is open.need to replace.
Air purifier filter smells bad
That's interesting... I doubt it is the filter if the new filter did the same. It might help if you take a fan and blow it through the area behind the filter, or maybe even spraying some Lysol in it, because my best guess is that something inside the purifier is what is causing the smell. Hope this helps!
