20 Most Recent Sony DDS SDT-5000 DAT Tape Drive Questions & Answers
supply an image (and would be great if you could supply image from old broken one and new one)
I'm a bit confused though: if you have an internal working sdt-5000 that you want to put into an external broken sdt-5000, it should be as simple as getting the enclosure open, then swapping the internal drives; i.e. external enclosures usually still use the same spec internal drive so it would just be an ide or scsi connector cable.
I’m happy to assist further over the phone at https://www.6ya.com/expert/shunter_ccf54e0913bd0501
Sony DDS... | Answered on Oct 14, 2016
I could help if I had more information about the problems your experiencing? You said that the tape drive is not working, but you didn't say what was wrong with it? What is it doing? Does it turn on, but it won't record a back up? Is it a problem with your system not recoginzing the drive? Have you checked to see if your system recognizes it? Did you download and install a driver before connecting the drive to your system? What is your operating system? Win Xp? Win 7? Vista? Does the light come on when you put a tape in the drive to signal that power is going to the drive? All of these questions are very relevant. There is not link for requesting a reply of confirmation on a paid question through Fixya. If you could go to your question on Fixya and use the reply or comment link to provide the above information I will help you solve this problem.
Sony DDS... | Answered on Aug 15, 2011
https://www.sony.com/electronics/support/televisions-projectors/kf-60we610/articles/S1Q0084
https://translate.google.com
Le voyant de la lampe clignote
Si l'?cran s'assombrit, que la couleur semble inhabituelle ou que le t?moin LAMP ? l'avant du t?l?viseur clignote, il est temps de remplacer la lampe par une nouvelle (non fournie).
Utilisez uniquement un Sony XL-2100U ou XL-2100 de remplacement pour votre t?l?viseur. L'utilisation de toute autre lampe peut endommager votre t?l?viseur ? projection LCD. Contactez votre revendeur Sony pour une lampe de rechange.
Cliquez ici pour t?l?charger des instructions ?tape par ?tape pour remplacer la lampe de votre t?l?viseur.
Remarque: Avant de remplacer la lampe, mettez l'unit? principale hors tension. Attendez quelques minutes, puis d?branchez le cordon d'alimentation. (Le ventilateur de refroidissement continuera de souffler pendant environ deux minutes apr?s la mise hors tension.)
Assurez-vous de laisser la lampe refroidir compl?tement avant de la retirer. La surface de la lampe reste extr?mement chaude pendant au moins 30 minutes apr?s la mise hors tension.
Sony Computers &... | Answered on May 03, 2020
Did you blow compressed air into laptop?. It is possible that something got disconnected or dirt stucked in powrr button
Sony Computers &... | Answered on Apr 22, 2020
Hi
You can read more such errors and their solution from the given link. This blog will help to analyze the Lotus Notes problems and give you the easy approach to resolve them smartly. This will enhance your knowledge about IBM and the tips to fix them.
Read more:- http://www.nsfsecurityremover.com/blogs/lotus-notes-error-messages/
Thanks
hi there might be...first go to my computer, then locate the dvd drive, right click that and then properties, then click the hardware tab at top then in the list locate dvd drive then at bottom right click on properties then click dvd region and then you should be able to change it....hope that helped
Sony Computers &... | Answered on Apr 17, 2020
You'll need a decoder from a program like cyber dvd or win dvd. Nero also has one and sonic too. If the drive came with a dvd player program install it. You can also find them through windows media player at microsoft's website but they will cost a few bucks. Search the internet for dvd player software you may find one for free. I hope this helps you. If you are like me you might have a program in your pile of software cds'.
Sony Computers &... | Answered on Mar 24, 2020
In Windows, open My Computer/Computer and explore/open the disk from it's drive.
Sony Computers &... | Answered on Mar 23, 2020
Do you have sound in other applications?
You could try using VLC Media Player, instructions here:
https://www.thewindowsclub.com/play-blu-ray-on-windows-10
Sony Computers &... | Answered on Feb 12, 2020
Hello there... Sony seems a choosy brand so it looks like your disc is not recognized by it. Check also your disc for scratches or you just need to clean your disc first before you can use it. Try it. If this doesn't help, try inserting your disc to other CD-ROM. See if your disc is okay. Hope this helps...
Ai-ai :)
Sony Computers &... | Answered on Jan 20, 2020
The push-button activates a small motor that turns a small rubber belt/ band that opens the cassette door. Since it's not been used for 10 yrs, I would say these belts would have deteriorated and broken. you will need to replace them. the best bet is to open it up and check. if its the case, you should be able to source the belts on ebay.
Sony Computers &... | Answered on Dec 03, 2019
this is easy, that OUT OF range means
the PC sending video is sending and illegall higher resolution
than the projector supports (or even less, on this old junk)
the manual on that old projector is clear on that. max.
SONY VPL-EX4 2007, 13 years old now.
and back then projectors STINK !
your manual shows this, and stinks.
what stinks worse is no matrix of legal H./V resolutions shown in the manual. (shows only 1)
so set the PC to 1400 x 1050 and do not use others . ok.
and 60Hz, are you in USA? not stated country.
Sony Computers &... | Answered on Nov 28, 2019
no OS stated, W10?
the drivers for your camera/mic are wrong, reload them from SONY..com
Looks like you are having a bad LCD screen, This could be due to drop damage. Cracks can be so tiny and may not be visible immediately. I would take it to a technician and get a screen replacement.
Sony Computers &... | Answered on Nov 27, 2019
Sony DDS SDT-5000 DAT Tape Drive Logo
2 questions posted
Top Sony Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
DDS Sony
  • DDS Sony
Most Popular Question
ive just bought old sony dat drive sdt
  • Computers & Internet
