20 Most Recent La Crosse Technology Ws-8418u-it Atomic Digital Wall Clock With Moon Questions & Answers
Fixya does not sell anything. The replacement batteries in the outdoor unit could be defective or installed incorrectly. The battery replacement procedure in the instructions must be followed exactly, i.e., batteries replaced in the outdoor unit then allowing time for the outdoor unit to begin sending data before installing batteries in the indoor unit to get an external temperature readout.
La Crosse... | Answered on Oct 09, 2014
Hi Susuan,
One of these methods below should get your device working properly. Good luck!
LaCorosse Tech Support email address.
The product information page
From the manual:
915MHz RECEPTION CHECK FOR OUTDOOR TEMPERATURE SENSOR
The atomic clock will receive the temperature data within 3 minutes. If the temperature data is not being received 3 minutes after setting up (the display shows "- - -"), then please check the following points:
1. The distance of the atomic clock or outdoor temperature sensor should be at least 6 feet (2meters) away from any interfering sources such as computer monitors or TV sets.
2. Avoid placing the receiver onto or in the immediate proximity of metal window frames.
3. Using other electrical products such as headphones or speakers operating on the same signal frequency (915MHz) may prevent correct signal transmission and reception.
4. Neighbors using electrical devices operating on the 915MHz signal frequency can also cause interference.
Note:
When the 915 MHz signal is received correctly, do not re-open the battery cover of either the outdoor temperature sensor or atomic clock, as the batteries may spring free from the contacts and force a false reset. Should this happen accidentally then reset all units (see Setting up above) otherwise transmission problems may occur.
The maximum transmission range is 330 feet (100 meters) from the outdoor temperature sensor to the atomic clock (in open space). However, this depends on the surrounding environment and interference levels. If no reception is possible despite the observation of these factors, all system units have to be reset (see Setting up).
La Crosse... | Answered on May 24, 2013
That means the *********** is invalid.
Possibly duplicated, stolen or bought from an untrusted vendor.
Computers &... | Answered 24 minutes ago
Free online conversion:
https://pdf2doc.com/
Or, purchase software that includes the conversion.
Computers &... | Answered 2 hours ago
In computing, a firewall is a network security system that monitors and controls the incoming and outgoing network traffic based on predetermined security rules.
Computers &... | Answered 19 hours ago
produce videos that are unique and entertaining.Send your link to your friends for them to follow and finally be always active on app
Computers &... | Answered Yesterday
Don't delete It. Backup to iCloud.
The Error Code oxc0000225 shows up after an update from OS, including upgrading from Windows 7 to Windows 10. The issue is the incorrect system disk. This can even happen if the PC turns off system files or even faulty equipment after a significant upgrade. You can't fix this problem from the inside of Windows, like other boot mistakes. But you would need to get a convenient Windows 10 disk upgrade tool for repair.
Just go through the link of a blog and follow the procedure.
View the blog:-
To update your Parrot CK3100, visit the support page at Parrot.com to check whether a new update is available. If an update is available, follow the steps described to update your device. Be aware that all contacts, photos and voice recognition data are erased during an update. Remember to make a backup beforehand!
1st possible solution: Check your hard drive(s) and partitions for errors. You can do this by going to My Computer > right click on a drive > Properties > 'Tools' tab > Check Disk or Check Now
2nd possible solution: You may have backed up your files from an NTFS system and are trying to restore to a FAT32 system. If so, convert your computer to NTFS by right clicking on 'My Computer' > Manage > Storage > Disk Management> Right click on your primary drive > and select convert to NTFS.
Computers &... | Answered 2 days ago
Hard drive or data error. Try and run chkdsk/f
Generally just running chkdsk/f will fix this error. its normally down to bad sectors on a failing hdd corrupting data.
if your hdd shows more than 1% errors get it replaced as its failing. if its just the odd soft error then full formatting. may solve the problem if chkdsk/f doesn't.
http://blogs.adobe.com/flashplatform/2011/02/update-for-fp-10-2-on-tabs.html
Adobe will offer Flash Player 10.2 pre-installed on some tablets and as an OTA download on others within a few weeks of Android 3 (Honeycomb) devices becoming available, the first of which is expected to be the Motorola Xoom.
We are excited about the progress we've made optimizing Flash for tablets, alongside partners including Motorola, and expect our momentum to continue. As we announced last week, over 20 million smartphones were shipped or upgraded with Flash Player in 2010 and over 150,000 consumers on the Android Market are rating it 4.5 out of 5 stars. We have raised our estimates for 2011 and expect to see Flash installed on over 132 million devices by the end of this year. Consumers are clearly asking for Flash support on tablet devices and the good news is that they won't have to wait long. We are aware of over 50 tablets that will ship in 2011 supporting a full web experience (including Flash support) and Xoom users will be among the first to enjoy this benefit.
**UPDATE (3/18/11): We're happy to announce that Flash Player 10.2 is now available for download on Android Market. To see if your device is certified for Flash Player 10.2, go to http://www.adobe.com/go/cd1. Note that this is a production GA (General Availability) release for Android 2.2 ("Froyo") and 2.3 ("Gingerbread") devices and an initial beta release for Android 3.0.1+ ("Honeycomb") tablets that include Google's system update (from 3.0 to 3.0.1).
We've been collaborating closely with Google and the beta of Flash Player 10.2 for Android 3.0.1+ is an exciting release offering a full web browsing experience, including video, games and other interactive content, to the latest Android tablets. A production GA version of Flash Player 10.2 for Android 3.0.1+ is expected in the coming weeks
It's a popular trend, so main advantage that your visitors will not think that you stuck in 200x =) Minimalistic, flat designs seems to be better for mobile devices, and it's easier to adapt such website for a number of devices, screen resolutions etc.
it should inspire you to please your boy/girlfriend
La Crosse Technology Ws-8418u-it Atomic Digital Wall Clock With Moon Logo
2 questions posted
Top La Crosse Technology Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a La Crosse Technology Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • La Crosse Technology Computers & Internet
Most Popular Question
outdoor temperature shows three lines
  • Computers & Internet
