20 Most Recent Visonik V700HC Car Audio Amplifier Questions & Answers
My visonik v700hc keeps going into protect
I suggest checking what ohm load you're presenting to that amp. go to www.the12volt.com and find the subwoofer wiring diagram and choosing the amount of subs you have on it and then the impedence of each one. you're probably sending too low of an ohm load to the amp this would cause it to go into protection quite frequently and eventually stay in protection.
5/31/2010 6:23:19 PM • Visonik V700HC... • Answered on May 31, 2010
0answers
How to remove visonik vcd51 head unit from car dashboard
This usually involves removing the plastic bezel around the stereo. Sometimes these plastic bezels hold some buttons for air conditioning and heat, as well as the hazard lights button. These plastic bezels usually are just snapped in with metal clips on the back of them. You can pry them outward and with a good yank they will pop out. Once you have the plastic bezel around the radio removed, there will be 2-4 screws on the sides, or top and bottom. Once you remove those, the whole radio will pull right out of the dash. Then you have to un-clip the wire harness from the car, and unplug the antenna cable. If you plan on putting a different stereo in the car, KEEP the mounting bracket around the stereo, as well as the "wiring harness" that was used to plug into the vehicle harness. That will save you about $50 in parts to put a new stereo in.
8/23/2016 4:51:41 PM • Visonik Car... • Answered on Aug 23, 2016
0answers
0answers
0answers
More clarification on the original question sub connection have no markings as + or - red or black nothing need to know which is what on these 12 dvc visonik subs if you put upside down which side is
To be absolutely sure of which terminal is positive and which is negative, we will use a 1.5 v battery to have the speaker react as though it is playing music.
* special note * do not use any more than 1.5 v as it may damage the speaker coil
As we know, batteries are marked positive, negative, or both ... we will use this to our advantage when hooking up the battery to our speaker.
To start the process, temporarily attach a short piece of wire to each terminal of the speaker (be sure to either use wire that is marked, or wire of differing colours to help determine which terminal is which). In our example, we used standard speaker wire which is "polarized" (one wire is made of copper and the other is made from tin .. interestingly, this serves no electrical purpose)
Once you have connected the wire to your speaker, proceed to briefly touch the free ends of the wire to the battery terminals (as shown below). In some cases, extended contact with the battery has caused cancer of the voice coil (ie. blown speaker)
If the speaker moves OUT when the battery is first connected, the battery is connected in proper alignment. Be sure to take note of which wire is connected to the positive terminal of the battery as this is your speaker's positive terminal.
8/18/2012 1:05:28 PM • Visonik Car... • Answered on Aug 18, 2012
0answers
Manual
Be the first to answer 3/11/2012 6:49:17 PM • Visonik Car... • Posted on Mar 11, 2012Be the first to answer
0answers
0answers
Visonik v543 speakers. there's
Hello sir hi, the black wire is standard color for ground. if you are wiring a speaker, the wire is really not that sensitive, interchanging the wire only makes the sound drop to about 2%, barely not noticeable.
9/19/2010 11:21:20 PM • Visonik Car... • Answered on Sep 19, 2010
How can you tell if your amp is blown.
Hello lilgeiger111,
If you have checked all of the wiring and fuses and the amp does not power up, it's blown.
Hope this helps.
8/19/2009 12:02:55 AM • Visonik Car... • Answered on Aug 19, 2009
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
4/18/2024 1:48:21 PM • Car Audio &... • Answered on Apr 18, 2024
Gathers car audio manual
How to change language to english for Honda Odyssey 2021 Gathers Radio Player
4/16/2024 4:19:39 PM • Car Audio &... • Answered on Apr 16, 2024
Visonik V700HC Car Audio Amplifier Logo
1 questions posted
Top Visonik Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Visonik Car Audio & Video
Most Popular Question
  • Car Audio & Video
