20 Most Recent Visonik V2000T Car Audio Amplifier Questions & Answers
chep all thewires and fuses make sure they are all secure
Visonik V2000T... • Answered on Dec 17, 2009
Don't! The amp will draw many more amps than what the 12V outlet (like a cigarette lighter) can handle. Most amps are wired directly to the battery (for the +12V) with a 30A or higher fuse (reference the owner's manual)
Visonik V2000T... • Answered on Mar 18, 2008
More details needed...
Where you installing?
Was it working for long before it happened?
Visonik V2000T... • Answered on Dec 15, 2007
This usually involves removing the plastic bezel around the stereo. Sometimes these plastic bezels hold some buttons for air conditioning and heat, as well as the hazard lights button. These plastic bezels usually are just snapped in with metal clips on the back of them. You can pry them outward and with a good yank they will pop out. Once you have the plastic bezel around the radio removed, there will be 2-4 screws on the sides, or top and bottom. Once you remove those, the whole radio will pull right out of the dash. Then you have to un-clip the wire harness from the car, and unplug the antenna cable. If you plan on putting a different stereo in the car, KEEP the mounting bracket around the stereo, as well as the "wiring harness" that was used to plug into the vehicle harness. That will save you about $50 in parts to put a new stereo in.
Visonik Car... • Answered on Aug 23, 2016
To be absolutely sure of which terminal is positive and which is negative, we will use a 1.5 v battery to have the speaker react as though it is playing music.
* special note * do not use any more than 1.5 v as it may damage the speaker coil
As we know, batteries are marked positive, negative, or both ... we will use this to our advantage when hooking up the battery to our speaker.
To start the process, temporarily attach a short piece of wire to each terminal of the speaker (be sure to either use wire that is marked, or wire of differing colours to help determine which terminal is which). In our example, we used standard speaker wire which is "polarized" (one wire is made of copper and the other is made from tin .. interestingly, this serves no electrical purpose)
Once you have connected the wire to your speaker, proceed to briefly touch the free ends of the wire to the battery terminals (as shown below). In some cases, extended contact with the battery has caused cancer of the voice coil (ie. blown speaker)
If the speaker moves OUT when the battery is first connected, the battery is connected in proper alignment. Be sure to take note of which wire is connected to the positive terminal of the battery as this is your speaker's positive terminal.
Visonik Car... • Answered on Aug 18, 2012
Hello sir hi, the black wire is standard color for ground. if you are wiring a speaker, the wire is really not that sensitive, interchanging the wire only makes the sound drop to about 2%, barely not noticeable.
Visonik Car... • Answered on Sep 19, 2010
Visonik V2000T Car Audio Amplifier Logo
Popular Tags
5 questions posted
Top Visonik Car Audio & Video Experts
xxxxxx xxx
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Visonik Car Audio & Video
Most Popular Question
visonik v4000xd
  • Car Audio & Video
