20 Most Recent Omron 3g3jv-ab002 Sysdrive 200v 0.25kw Varispeed Inverter Drive 1-phase Questions & Answers
Compare Apex Practitioner Microscope v C & A Scientific MFL-06 My First Lab Duo-Scope?
You are probably qualified by now but you question was resurrected by and AI Bot. https://www.google.com/search?q=Apex+Practitioner+Microscope+vs+C+%26+A+Scientific+MFL-06 ..
12/30/2023 9:34:23 PM • Science &... • Answered on Dec 30, 2023
Little Sister 3 Autoclave is displaying FILL but does not actually fill and goes no further. What can I do?
Technical Manual and other suggestions. Professional machines really need professional service as the repair is very specialized, and the dangers of using incorrectly sterilized tools injurious to health.
T echnical Manual
Frank's Hospital Workshop http://www.frankshospitalworkshop.com > Esch... The SES Little Sister 3 is a portable electrically operated steam autoclave suitable for the sterilization of unwrapped metal instruments and utensils. 4. The ... 47 pages
Watch out for These 7 Common Autoclave Problems
Consolidated Sterilizer Systems https://consteril.com > common-autoclave-problems 1. The sterilizer won't reach the temperature set-point. · The steam generator is need of repair. · There is a clog in the chamber drain (i.e. check the chamber ... Missing: Sister ‎' Show results with: Sister
11/19/2023 6:33:32 PM • Science &... • Answered on Nov 19, 2023
Eppendorf 5402 centrifuge front screen not working
you are right, there is no manual, except for the 5420. Try here, they do Sales and Service as well https://www.gmi-inc.com/product/eppendorf-5402-refrigerated-centrifuge/ and you can still buy them https://angelusmedical.com/products/eppendorf-5402-refrigerated-micro-centrifuge-parts-only Did you ask them direct for support? Did you open it up and check Ribbon Cable connections?
Centrifuge and Rotor Service
Eppendorf https://www.eppendorf.com > ca-en > service-support epServices offers rotor assurance plans. Read more about the professional inspection services and evaluation of centrifuge rotors and buckets.
Service & Support
Eppendorf https://www.eppendorf.com > ca-en > service-support The services range from technical support and troubleshooting to delivery of replacement parts on short notice and customer-specific maintenance programs. ULT ...
Service & Support
Eppendorf https://www.eppendorf.com > your-centrifuge-solutions We provide efficient, reliable services for your centrifuge. Our ... Includes a full annual preventive maintenance service program for assured instrument ...
10/11/2023 7:38:15 PM • Science &... • Answered on Oct 11, 2023
What is the E009 problem and how to repair please.
The Autoclave door is not opening at the end of the cycle.
Midmark M11 "Old Style" Error Code E009
Sterilizer Autoclave Solutions https://statimusa.com > midmark-m11-old-style-error-... Error E009: Door doesn't fully open at the end of a cycle. This error indicates that there is pressure buildup during the dry cycle. Probable causes of Midmark ...
Error Code E009 :
AllClaveParts https://www.allclaveparts.com > error-code-e009 You will need to know whether or not the Door is Opening Automatically at the End of the Cycle when you get the Error Code E009 before proceeding.
4/1/2023 3:34:52 AM • Science &... • Answered on Apr 01, 2023
AA-Spectrometer Unicam 939 Error
The error you are experiencing on your Unicam 939 AA-Spectrometer with the software reporting error 16 and 2, along with lamps 1,2,3,4, and 10 lighting up, could indicate a few different issues. Here are some steps you can take to try to fix the problem:
  1. Restart the spectrometer: Turn off the spectrometer and unplug it from the power source. Wait a few minutes, then plug it back in and turn it on again. Sometimes, a simple restart can fix issues with the instrument.
  2. Check the calibration: It is possible that the instrument needs to be calibrated. Follow the manufacturer's instructions for calibrating the spectrometer.
  3. Check the lamps: If multiple lamps are lighting up, it could be due to a problem with the lamp assembly. Check that the lamps are properly installed and functioning. Try replacing any lamps that appear damaged or worn.
  4. Check the power supply: Make sure the power supply is functioning properly by testing the voltage output with a multimeter. If the voltage output is incorrect, try replacing the power supply.
  5. Check the communication between the software and the spectrometer: Ensure that the software is properly communicating with the spectrometer. Check that the cables are properly connected and that the software settings are correct.
If these steps do not resolve the issue, it may be necessary to contact the manufacturer for additional support or to seek the assistance of a professional repair technician.
3/24/2023 6:39:35 AM • Science &... • Answered on Mar 24, 2023
Eppendorf centrifuge model 5702: lid not does latch/lock after emergency release.
If the lid of your Eppendorf centrifuge model 5702 is not latching or locking closed after the emergency release, it is possible that the locking mechanism is damaged or misaligned. Here are some steps you can try to troubleshoot the issue:
  1. Check the alignment of the lid: Make sure that the lid is properly aligned with the base of the centrifuge. If it is not, the locking mechanism may not engage correctly. Adjust the lid as needed and try to latch it closed.
  2. Inspect the locking mechanism: Check the locking mechanism on both the lid and the base of the centrifuge for any signs of damage or wear. If you see any damage, you may need to replace the locking mechanism.
  3. Check the safety interlock switch: The safety interlock switch is a small button located on the base of the centrifuge that is depressed when the lid is closed. If this switch is not working correctly, it can prevent the lid from latching closed. Check that the switch is functioning properly by pressing it with a small tool while attempting to latch the lid.
  4. Contact Eppendorf customer support: If none of the above steps work, you may need to contact Eppendorf customer support for further assistance. They can help you troubleshoot the issue and provide advice on how to proceed.
3/15/2023 4:55:19 AM • Science &... • Answered on Mar 15, 2023
Enigma 8 autoclave error code E13
The E13 error code on an Enigma 8 autoclave typically indicates a problem with the vacuum system. This error code is indicating that the vacuum is not reaching the proper level during the sterilization cycle. Here are a few things you can check to fix the E13 error code:
  1. Check the vacuum pump: Make sure that the vacuum pump is functioning properly and that it is not blocked or clogged.
  2. Check the air filter: Make sure that the air filter is clean and not clogged. A clogged air filter can prevent the vacuum pump from functioning properly.
  3. Check the vacuum hose: Make sure that the vacuum hose is not damaged or disconnected.
  4. Check the door gasket: Make sure that the door gasket is not damaged or leaking. A damaged or leaking door gasket can prevent the vacuum from reaching the proper level.
  5. Check the control board: Make sure that the control board is not damaged or malfunctioning.
  6. Check the water level: Make sure that the water level is at the correct level in the autoclave chamber.
1/14/2023 10:21:30 PM • Science &... • Answered on Jan 14, 2023
Zeus's Acuitus 5015 only reads left eye.
Contact Carl Zeiss direct. That is well beyond the scope of Fixya, sorry. https://www.google.com/search?q=Zeus%27s+Acuitus+5015 ..
1/5/2023 6:23:50 PM • Science &... • Answered on Jan 05, 2023
What type of lightbulb does an Alexis Scientific microscope model # 0672129 take?
Unfortunately too old for the internet to know too much about it. https://www.google.com/search?q=Alexis+Scientific+microscope+0672129+bulb This a 6 volt bulb https://www.indiamart.com/proddetail/microscope-bulbs-11691798697.html The is also a 115 volt, 15 watt from a school supply shop. It depends if it originally had a transformer to drop the power or used mains? https://select.schoolspecialty.ca/incandescent-replacement-microscope-bulb-medium-bayonet-563263 ..
8/17/2022 11:27:47 PM • Science &... • Answered on Aug 17, 2022
3answers
I need eppendorf 5402 refrigerated centrifuge service manual
I don't see the service manual posted on the net, simply an operator's manual. Whether you can get such from the company's technical support is unknown as they have a lot of service contracts offered. You might post on Labwrench to see if someone has such and would upload it. Here are Eppendorf contacts and a superflous operator's manual: https://www.eppendorf.com/US-en/service-support/repair-service/ https://www.eppendorf.com/US-en/service-support/ https://www.eppendorf.com/product-media/doc/en/781602/Centrifugation_Operating-manual_Centrifuge-5420.pdf https://www.labwrench.com/equipment-results?q=centrifuge+5402 https://www.fixya.com/support/t22172056-5402_error_2 1 (800) 645-3050 Eppendorf customer service https://www.masontechnology.ie/brand/eppendorf/
5/5/2022 1:27:17 AM • Science &... • Answered on May 05, 2022
We have APEL PD 303UV spectrophotometer in our
spectrophotometer in our lab. When it is started, it displays' "selftesting monochromator err".Please help and guide me to diagnose and rectify problem. Please reply me at this email address. [email protected]
5/4/2022 10:50:19 AM • Science &... • Answered on May 04, 2022
The Pelton & Crane autoclave in my office keeps giving me a P-2 code and will stop running. Anybody know what this could mean?
Question re-worded for clarity. Sterilizer Manufacturer: Pelton & Crane Model of Sterilizer: Problem Title: DELTA 8 10 Error P2: Sterilizer Pressure reaches 241 Kpa before 135'C temperature Problem Description: DELTA 8 10 Error P2: Sterilizer Pressure reaches 241 Kpa before 135'C temperature Reasons 1. DELTA 8 10 Error P2: Sterilizer Pressure reaches 241 Kpa before 135'C temperature First, check the sterilizer can return the air/steam back from chamber to reservoir or not between 90C to 110C. It is very important to make sure all air will be purged out of the chamber. Only pure steam, the temperature can match pressure. If not return, check the bellow solenoid or the Power PCB board 2. If the air purging works well between 90'C - 110'C, then check the RTC (steam) sensor to make sure it is properly connected to the Power PCB board
3/9/2022 7:11:47 PM • Science &... • Answered on Mar 09, 2022
Omron 3g3jv-ab002 Sysdrive 200v 0.25kw Varispeed Inverter Drive 1-phase Logo
1 questions posted
Top Omron Science & Laboratory Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Collins Mccoy
Collins Mccoy
Are you an Omron Science and Laboratory Expert? Answer questions, earn points and help others
View Most Popular
  • Omron Science & Laboratory
Most Popular Question
delete memory
  • Science & Laboratory
