20 Most Recent Cub Cadet LS27CCHP - 27-Ton Horizontal / Vertical Gas Log Splitter Questions & Answers
2answers
Runs fine for few minutes then dies like running out of gas then choke it it starts runs then does it again over and over
You have a feeling issue..
By choking the engine, you restrict the airflow, thus reduce the amount of fuel being drawn through the carb, meaning it's burning a sufficient amount of fuel and air.
When the choke is off, it's getting too much air for what can be drawn through the carb, meaning you have a furlong issue.
5/30/2016 5:49:57 PM • Cub Cadet... • Answered on May 30, 2016
Have a 1998-99 c-series 863 Bobcat.
The Bobcat 863 is a skid steer loader model manufactured by Bobcat Company, a renowned manufacturer of construction equipment. The 863 model was produced from 1996 to 2003 and was part of the C-Series lineup. Here are some key details about the Bobcat 863:
  1. Engine: The Bobcat 863 is powered by a diesel engine. The 863 was initially equipped with a Deutz BF4M1011F engine, which is a four-cylinder, turbocharged engine. Later models may have variations in engine specifications.
  2. Operating Capacity: The operating capacity of the Bobcat 863 depends on the specific configuration and attachments used. However, it typically falls within the range of approximately 1,500 to 2,000 pounds (680 to 907 kilograms).
  3. Hydraulic System: The 863 features a hydraulic system that powers the loader arms and attachments. It has auxiliary hydraulic ports for connecting various hydraulic-powered attachments, such as buckets, forks, grapples, and hydraulic hammers.
  4. Controls: The 863 is equipped with joystick controls that allow the operator to maneuver the machine with precision. These controls enable the operator to manipulate the loader arms, drive functions, and auxiliary hydraulics.
  5. Attachments: The Bobcat 863 is compatible with a wide range of attachments, making it versatile for various applications. Common attachments include buckets for general-purpose loading, forks for material handling, augers for digging, and sweepers for cleaning.
  6. Safety Features: Like all Bobcat equipment, the 863 is designed with safety in mind. It features safety interlock systems to prevent accidental operation and rollover protection structures (ROPS) to protect the operator in the event of a tip-over.
  7. Maintenance: Regular maintenance is essential to keep the Bobcat 863 operating efficiently. This includes routine checks of fluid levels, engine oil, hydraulic system, filters, and tire pressure.
3/8/2024 3:25:54 PM • Heavy Machinery • Answered on Mar 08, 2024
2007 JCB 3CX Sitemaster. Hi am searching for workshop manual catalogue for it please.
JCB 3CX SERVICE MANUAL Pdf Download
ManualsLib https://www.manualslib.com > ... > 3CX View and Download jcb 3CX service manual online. Backhoe Loader. 3CX compact loader pdf manual download. Also for: 214, 4cx, 214e, 215, 217.
3/6/2024 7:10:24 AM • Heavy Machinery • Answered on Mar 06, 2024
Volvo L180G Loader. How to I view fault codes on it please.
You connect a standard OBD (on board diagnostics) code reader. You need the service manual. OBD is mentioned in the advertising brochure on Page 21.
LIMMG, LI8MG, L22MG - cloudfront.net
cloudfront.net https://dizv3061bgivy.cloudfront.net > l180g PDF Best in class on-board diagnostics with fault codes. L150G, L180G, L220G. Voltage. V. 24. Batteries. V. 2 x 12. 32 pages
VOLVO L180G Wheel Loader Service and Repair Manual
eManualOnline https://www.emanualonline.com > ... > L 180 G Fixing problems in your vehicle/truck is a do-it-approach with the VOLVO CONSTRUCTION Repair Manuals as they contain comprehensive instructions and ... US$63.99 · ‎In stock
3/6/2024 7:09:39 AM • Heavy Machinery • Answered on Mar 06, 2024
2answers
I want to know what causes fault code E11-CA2249 on my excavator kumatsu pc220
E11 CA2249 Rail Press Very Low Error ENG Electrical I'd guess that if there's no leakage or power loss then it's most likely a fault in the sensor.
3/6/2024 7:05:16 AM • Heavy Machinery • Answered on Mar 06, 2024
G6 Error code for a Raymond Electric Fork Lift model number EASI-R35TT?
The G6 error code on your Raymond Electric Fork Lift model EASI-R35TT indicates a specific issue. Let's break it down: F5 Code: The F5 code typically points to an internal VFC (Variable Frequency Controller) fault. This component is crucial for controlling the motor speed and other functions. If the VFC is malfunctioning, it can trigger the F5 error. 6G Code: The 6G code signifies an overtemperature condition related to the lift motor. It indicates that the motor has exceeded safe operating temperatures. Here are some steps to troubleshoot and address the issue: Check Grounds: Ensure that all electrical connections and grounds are secure. Sometimes, a loose or faulty ground can cause unexpected errors. Battery Inspection: Although you mentioned the battery is at 72%, it's essential to thoroughly inspect it. Make sure the battery terminals are clean, and there are no signs of corrosion. A weak battery can lead to various issues. VFC and Display Verification: Verify that the VFC (Variable Frequency Controller) and the display match the original configuration for this specific truck. If there have been any replacements or swaps, it could affect the error codes. The display holds critical information about the truck's options and settings. Thermistor and Load Weight: You mentioned that the truck attempts to read load weight even though there's no pressure transducer installed. The 6G code relates to a thermistor (temperature sensor), which might be falsely triggering. Check the thermistor circuit and ensure it's functioning correctly. Remember that diagnosing forklift issues can be complex, and professional assistance may be necessary. If the problem persists, consider reaching out to a certified technician or the manufacturer for further guidance. Good luck with resolving the issue, and may your forklift be back in smooth operation soon!
3/6/2024 7:04:25 AM • Heavy Machinery • Answered on Mar 06, 2024
2answers
Why is my GX160 hard to pull start?
Possibly it overheated with the strain and has partially seized. Put a few drops of light engine oil ointo the cylinder and if that helps with the tightness, look for another engine or a rebuild.
9/2/2023 5:40:02 PM • Heavy Machinery • Answered on Sep 02, 2023
FG30N keeps blowing qgs fuse
read the schematic, is fuse for glow plugs or what? GK25E , engine? the sales pages show 3 engines, gas./LP or diesel
6/28/2023 1:33:49 PM • Heavy Machinery • Answered on Jun 28, 2023
2answers
I have a International Harvester 706. The front end loader is lopsided and won't hardly lift any weight. The hydraulic oil level is full. Any ideas?
cylinders are leaking or pump is bad or relief is leaking. take to repair shop
5/19/2023 3:42:38 PM • Heavy Machinery • Answered on May 19, 2023
Mitts and Merrill m4 chipper knives replacement how to
Before replacing the M4 chipper knives, prioritize safety by turning off and disconnecting the chipper from the power source. Then, locate the access points or covers that provide entry to the knives for a safe and efficient replacement process, then you have to ensure the chippers safety, then carefully unscrew the bolts or remove the clamps that secure the old M4 chipper knives, allowing access for their replacement and maintenance an once the old M4 chipper knives are removed, carefully align and insert the new knives into the slots or mounting holes, ensuring they match the orientation of the previous knives. Secure them in place with the appropriate bolts or screws, and perform a thorough inspection to ensure proper alignment and functionality.
5/17/2023 11:55:38 PM • Heavy Machinery • Answered on May 17, 2023
Case 1840 Uni-loader Fuse box diagram please?
No free ones, but a link to the Service Manual. There are free schematics to wiring. https://www.google.com/search?q=Case+1840+Uni-loader+Fuse+box+diagram ..
4/1/2023 10:02:11 PM • Heavy Machinery • Answered on Apr 01, 2023
I need a Manual for a Millers Falls TWM 13HP Wood Chipper, Shredder, Mulcher - it has the JiangDong JF390 engine. I can't seem to find one anywhere - can you help? Regards - Steve
Here are some general steps you can take to try to locate a manual:
  1. Check the manufacturer's website: Check the Millers Falls website to see if they have a manual available for download. If not, you may be able to contact their customer support for assistance.
  2. Search online: Search for the manual on websites such as ManualsLib or ManualsOnline. You may also find helpful information or user manuals on forums dedicated to chippers and shredders.
  3. Contact a local dealer: Contact a local dealer that sells Millers Falls products. They may have access to the manual or be able to order one for you.
  4. Contact the engine manufacturer: Since you have the engine manual, you could contact JiangDong directly and ask if they have a manual for the chipper and shredder.
If you are unable to find the specific manual for your chipper and shredder, you could try using the engine manual as a reference for basic maintenance and troubleshooting. However, be sure to use caution and follow all safety precautions when operating the equipment.
3/19/2023 12:36:49 AM • Heavy Machinery • Answered on Mar 19, 2023
Looking to rectify error code for L 506-1577
Greetings, I read your question and I think heavy-equipmentmanual.com can help you in this. Here's the site link - https://www.heavy-equipmentmanual.com/
3/9/2023 6:38:00 AM • Heavy Machinery • Answered on Mar 09, 2023
Can someone please provide the tolerance / spacing / gap between the rotating blade and the fixed blade on a Lescha-Zak 1800 electric Chipper?
If you want to solve your problem, click on the link I attach https://www.heavy-equipmentmanual.com/
3/6/2023 6:44:15 AM • Heavy Machinery • Answered on Mar 06, 2023
Vermeer 252 stump grinder moves slow when cold. boom moves back and forth and up and down with no problems. just slow movign forward or backwards
possible normal operating --depending on weather-- until unit warms up the fluid is denser and slows functions ------check fluid level -and that correct fluid is in unit
3/4/2023 12:46:39 PM • Heavy Machinery • Answered on Mar 04, 2023
Hi, my New Holland LS 170 quit while working with it. I turn the key the alarm sounds but the starter doesn't crank at all. Any help appreciated. Thanks
check and test safety switches -fuses relays -connections------https://www.manualslib.com/products/New-Holland-Ls170-11069316.html
3/4/2023 12:33:17 PM • Heavy Machinery • Answered on Mar 04, 2023
Toyota 6 FDF 30 with 2Z engine, torque settings for big ends main bearings cylinder head bolts in forklift Toyota 6 FDF 30 please.
There is some help here but really, you should invest in a Service Manual. https://www.google.com/search?q=Toyota+2Z+engine%2C+torque+settings+for+big+ends+main+bearings+cylinder+head+bolts Service Manual is 10 bucks
Toyota Forklift Trucks 2Z Model Engine Service Repair
https://filesmart.sellfy.store > bhxomv This Toyota Service / Repair / Workshop Manual PDF Download contains specs, diagrams, actual real photo illustrations, and schemes. In addition to space savings ... US$9.85 ..
3/3/2023 9:43:16 PM • Heavy Machinery • Answered on Mar 03, 2023
Cat V40C Forklift. I need the wiring schematics please?
Question edited for clarity. The wiring schematic is here, but just join them and shrink wrap. https://f01.justanswer.com/BradleyT416/710afd2f-5fbd-4ccd-927b-3864e183dee6_vc60.pdf ..
3/3/2023 7:44:29 PM • Heavy Machinery • Answered on Mar 03, 2023
Cub Cadet LS27CCHP - 27-Ton Horizontal / Vertical Gas Log Splitter Logo
2 questions posted
Top Cub Cadet Heavy Machinery Experts
ADMIN Andrew
ADMIN Andrew
Dmitry Isayev
Dmitry Isayev
Are you a Cub Cadet Heavy Machinery Expert? Answer questions, earn points and help others
View Most Popular
  • Cub Cadet Heavy Machinery
Most Popular Question
runs fine few minutes dies like running
  • Heavy Machinery
