20 Most Recent Kenwood TS-790A Questions & Answers
No Audio
Hi Marty, ..ok, baring anything else acting up, like a airplane before take off , if the audio was working then and not now , you have probably over looked something in pre flight, check all antenna connections, check the external spkr jack your plugged in to , check all buttons, make sure your on a real ch#, check your squelch adjust. and if you changed mikes , make sure its wired correctly for the radio, if there is any other possible human error it's unknown to me. nice radio...gd luck to you...
12/17/2017 9:36:28 AM • Kenwood TS-790A • Answered on Dec 17, 2017
La funci?n del subwoofer no funciona en mi kenwood DNX6140 que debo hacer
ask in English?
1/5/2020 9:01:27 PM • Kenwood... • Answered on Jan 05, 2020
Kenwood dnn990hd wifi doesn't work
How this unit accesses the Internet is via a smart phone you provide that is in Portable Wi-Fi HotSpot Mode. After setting your phone up to serve as a HotSpot, do setup the Kenwood dnn990hd wifi's wifi as you would a smart phone's wireless connection. If you need more instructions on how to the above, please provide the make and model of your smartphone, as the navigation to the settings have changed from version to version in Android and other OS's are just plain different altogether!~
7/12/2019 7:16:47 PM • Kenwood... • Answered on Jul 12, 2019
F3 error code kenwood 04 ton ac
The Possible Causes of the errors are:- Wiring Mistake or Wiring Problem Bad Sensor or not work properly Bad PCB Board on your ac The PCB computer board that controls a mini split is having a problem seeing the correct voltage from the sensors it uses. The wiring and many sensors need to be checked to see if they are malfunctioning. Indoor room temperature sensor. To troubleshoot a unit the location of the many sensors will need to be known. This information can be found in the manual for the unit and depending on the manufacturer may be available from their website. It is also possible that the PCB board has gone bad. If after testing all the sensors and wiring and they show good this usually points to a bad PCB board. Another thing that can cause problems is a unit wired wrong or wiring that has a short or open. Most often these errors require a technician and will be outside the average home DIY job. http://www.hvachowto.com/2017/06/15/e4-e5-e6-f1-f2-f3-error-codes-on-a-mini-split
7/6/2019 9:09:54 AM • Kenwood... • Answered on Jul 06, 2019
Need 4 digit unlock code for kenwood kvt514
Try these steps...click the link
http://www.tech-faq.com/how-to-reset-a-kenwood-security-code.html
6/4/2019 6:04:29 PM • Kenwood... • Answered on Jun 04, 2019
Kenwood M-A300 not powering on
https://www.hifiengine.com/manual_library/kenwood/m-a300.shtml You need to make an account for their website, but they have a detailed service manual. Probably the internal fuse is blown.
1/21/2019 11:00:44 AM • Kenwood... • Answered on Jan 21, 2019
0answers
Kenwood PS series DC power supply - maximum voltage issue
First thing to do is check the unit with an external meter to see if the internal ones are accurate.
3/17/2017 6:06:21 PM • Kenwood... • Answered on Mar 17, 2017
0answers
0answers
Kenwood TS-790A Logo
2 questions posted
Top Kenwood Computers & Internet Experts
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Kenwood Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Computers & Internet
Most Popular Question
no audio
  • Computers & Internet
