20 Most Recent GE JES1290 Convection/Microwave Oven Questions & Answers
Keypad 3 & 9 do not work on ge jes1290
The keypad control board must be replaced, cost can rival some microwaves.
3/4/2019 8:39:44 AM • GE JES1290... • Answered on Mar 04, 2019
When open the door the fan its work
One of the internal micro switches may be faulty, have them checked
8/23/2014 1:41:10 AM • GE JES1290... • Answered on Aug 23, 2014
0answers
My microwave/convection oven (a GE unit model
The technical sheets in my files do not list F6 on the error code chart for GE microwaves.
Generally, these are the error codes possible on GE microwaves:
F1 open thermal sensor (convection models)
F2 shorted thermal sensor (convection models)
F3 key panel shorted for more than 60 seconds
F4 open humidity sensor
F5 shorted humidity sensor
There should be a "mini-manual" (technical sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
3/20/2013 10:49:57 PM • GE JES1290... • Answered on Mar 20, 2013
Convection oven doesn't heat
Possible that the relay is faulty or there is fault on the control panel. It can also be related to problems on the thermocouple or sensors which can cut off prematurely the element.
2/12/2013 12:24:48 PM • GE JES1290... • Answered on Feb 12, 2013
Ge jes1290 issues
What are the issues?
4/9/2012 9:58:00 PM • GE JES1290... • Answered on Apr 09, 2012
Ge jes1290 keep tripping my breaker when i plug it in
The magnetron is probably shorted, considering prices of parts, a new replacement would be more practical.
4/9/2012 1:38:41 PM • GE JES1290... • Answered on Apr 09, 2012
Turnable is still on when the door is open, it
It may be door switch or switch mount trouble.See our help file on door switches here.Or it may be a shorting relay on the control circuit board, which can be repaired. More info here. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
10/18/2011 3:33:06 AM • GE JES1290... • Answered on Oct 18, 2011
Hi! I need a manual
I found your manual HERE.
Happy to help, Please rate service and comment, Thank you,
Joe
9/1/2011 12:20:14 AM • GE JES1290... • Answered on Sep 01, 2011
Clock, timer ,key board work ..but set time and it
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
3/20/2011 10:07:44 PM • GE JES1290... • Answered on Mar 20, 2011
0answers
Jes1290 microwave runs but no
Hi, if it keeps running when the door is open, that's usually due to a bad door switch or broken / loose door switch mount. You just need to fix the door switch or door switch mount to solve the problem....
10/11/2010 10:51:13 PM • GE JES1290... • Answered on Oct 11, 2010
Where is the fuse located?
If the model number is correct, there is a small input line filter board with a 125V, 20 AMP line fuse inside the microwave. Its usually mounted on a small input line filter board at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line filter is listed as item 1420. The fuse will be mounted to this board.
You can purchase replacement fuses at any hardware store. You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Slow Blow fuses are recommended.
If you have any questions, or need assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit.
4/24/2010 2:25:48 PM • GE JES1290... • Answered on Apr 24, 2010
I have the same problem, and plastic cover is scorched w/ hole
Hi! the problem you have mentioned indicates that your microwave magnetron is not working. check for busted fuses.
9/15/2009 11:48:41 PM • GE JES1290... • Answered on Sep 15, 2009
It makes noise like it's working but isn't
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
8/11/2009 11:45:29 PM • GE JES1290... • Answered on Aug 11, 2009
GE JES1290 Convection/Microwave Oven Logo
36 questions posted
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
convection oven doesn 39 t heat
  • Microwave Ovens
