20 Most Recent Philips (PM625S) Remote Control Questions & Answers
The code for GE universal remote for th Durabrand BH2004D is "0157"
Philips (PM625S)... | Answered on May 30, 2009
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Philips... | Answered on Mar 29, 2020
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Unfortunately, I don't think you can connect this sub-woofer without the rest of the components of the HTS3440/37 DVD Home Theater System or a related Philips home theater system. The speakers in the system are hard-wired with a colored plug that you connect to the sub-woofer. Then you need connect the inter-connect cable between the sub-woofer to the DVD Player of the system. See the wiring guide in the Quick Start Manual or the User Guide available on the product support page: https://www.usa.philips.com/c-p/HTS3440_37/divx-ultra/support .
Sub-woofers that aren't part of a home theater system connect to a receiver with a digital audio RCA cable. One example is here: https://www.amazon.com/Mediabridge-ULTRA-Subwoofer-Cable-Feet/dp/B003FVYXY0 . Then the speakers also connect to the receiver.
Even if you find another Philips Home Theater system that is missing the sub-woofer, I wouldn't rule out a change in the pin arrangement for the inter-connect cable that would cause the system to fail. I can't find any sources for a replacement inter-connect cable; the part number isn't in the manual that I can find.
I wish that I had better news for you.
Philips... | Answered on Mar 25, 2020
https://www.google.com/search?sxsrf=ALeKk01WXYf7C0T8rMi9ZryD8CeMY45YWA%3A1585158210467&source=hp&ei=Qph7XtDvGYfNrgSHh6gI&q=how+we+program+my+Philips+universal+remote+for+my+Orion+TV+don%27t+know+how+old+the+remote+is&oq=how+we+program+my+Philips+universal+remote+for+my+Orion+TV+don%27t+know+how+old+the+remote+is&gs_l=psy-ab.3...3099.23401..26745...4.0..0.630.5472.2-2j5j6j1......0....2j1..gws-wiz.....10..35i362i39j35i39j35i304i39.VpH5PWtMe7o&ved=0ahUKEwjQmK7AlrboAhWHposKHYcDCgEQ4dUDCAU&uact=5#kpvalbx=_vpl7Xo-YI4SR8gLWqqDQBw37
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Philips... | Answered on Mar 14, 2020
No one buys universal remotes any longer. you can get exact facsimile remotes of Amazon and ebay.
Philips 2084, 2434, 1241
Philips... | Answered on Mar 13, 2020
Ah, the let's try changing this method of repair.
Here is a question that we see often.
Question:
I've replaced everything in my television because it previously had a black screen with no lighting. Now it doesn't turn on at all and all I have is audio. What could be the cause ?
So your television stops working properly and you think it must be easy to fix, because you can buy boards on eBay, and you can watch YouTube videos. So you make a decision, you buy a board and you fit it, but the television still doesn't work! This is a classic case of the 'let's try replacing this' method of television repair and illustrates why it is a bad idea. It doesn't work for a number of reasons. To correctly diagnose issues, you need to know every board, what is does and every component on the board. You need to know which part has failed, replace the component, or replace the board. The parts you purchased off eBay were probably out of scrapped sets and not tested. The part you put in was dead when you put it in, so you just moved on to another guess at what might be the cause and replace a board that is fine. And so it goes on, you change all the boards and it still doesn't work. Did you notice the large print that says 'No Refunds, NO Returns'. This is to stop you sending your old one back and saying it didn't work, but the unscrupulous use it as an excuse to get money for selling items that may not work! The course to be a television engineer is 2 years full time education, take it to someone that knows how to diagnose and fix. It is by far the cheapest option. The part that failed might be a 20 cents fuse diode hard soldered to a board. They will charge you $2 parts and an hours labour.
Philips... | Answered on Mar 06, 2020
We discarded our Philips BluRay for this reason. It could play only about half the Netflix BluRay discs we tried on it. Ask Philips at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Philips... | Answered on Mar 04, 2020
i think not...beacuse the model varries....for more details visit there website/ or refer to their manuals.
Philips... | Answered on Feb 21, 2020
To change the region on the Philips dcp750
1. Press the Open button on your remote control to open the drive tray
2. Press the Setup button on your remote control
3. Press the Right button on your remote control
4. Press the Right button on your remote control
5. Press the Right button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 5 button on your remote control
9. Press the 3 button on your remote control
10. Using the Up and Down buttons on your remote control, change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
11. Press the Setup button on your remote control
Philips... | Answered on Feb 13, 2020
You need contact anyone from Philips Support using their HOTLINE since as per your description the TV is already defective and check whether it is still under warranty if not you'll need to pay for repair cost.
Philips... | Answered on Feb 08, 2020
Try unplugging it from the mains for 10 mins and then plugging it back and switching it on.
Philips... | Answered on Feb 01, 2020
Televison & Video Logo
3 questions posted
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
durabrand tv model bh2004d need code ge
  • Televison & Video
